Old 04-07-2010, 06:11 PM   #1
jtragolia
Drives: pontiac grand am
Injen Cold Air Intake Whistling Sound?
I recently purchased and installed the Injen Cold Air Intake. Since the first day I've noticed an actual whistling sound while accelerating. I've had a cold air intake on my previous two vehicles and never heard this type of noise before. It isn't the sound of air being pulled into the filter it is definetly a whistling sound. Any ideas on what could be causing this, is this common, and is there a fix for this?
jtragolia is offline   Reply With Quote
Old 04-07-2010, 06:27 PM   #2
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Well any Injen CAI I have heard has had that whistling sound. I have heard it come out of any CAI that snorkels down to the fenders.
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 04-07-2010, 06:47 PM   #3
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Mine whistles too... i'm thinking the tube inside a tube... ???
scrming is offline   Reply With Quote
Old 04-07-2010, 06:55 PM   #4
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Well, from Injen " This intake system is equipped with the first ever Air Intake Horns " Patent pending
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 04-07-2010, 07:23 PM   #5
jtragolia
On my previous cars I had different brand cold air intakes, this is my first experience with injen.
Old 04-07-2010, 08:28 PM   #6
D Vegas
D Vegas's Avatar
Drives: 2010 1LT/RS VR,1978 VW BUG CV
The Airaid does it also at light throttle. i think its common with most intake systems seeing they are just straight through pipes and no way to suppress noise that i think is caused by air going through the throttle body when its only open a small amount.
D Vegas is offline   Reply With Quote
Old 04-07-2010, 10:16 PM   #7
bucky1399
bucky1399
bucky1399's Avatar
Drives: 1LT, '99 Chevy ZR2
Just bought the Injen but haven't installed it yet. How annoying is the whistling? Is it worth it to install or should I just stick with stock?
bucky1399 is offline   Reply With Quote
Old 04-07-2010, 10:18 PM   #8
mrray13
Drives: 2010 1LT RS Rally Yellow
It's not annoying at all. Well worth the install!! The whistling only happens when you are on the go pedal! It's actually kinda cool!
mrray13 is offline   Reply With Quote
Old 04-07-2010, 10:42 PM   #9
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Install it, the whistle is not there unless you know to listen for it !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 04-08-2010, 10:00 AM   #10
mikdz06
Drives: 2010 camaro
Injen
Yes mine has the whistle too, kind of sounds like a turbo, does not seem to be a problem. Had to go back and tighten clamps up a couple of times, but that is normal, nice unit.
mikdz06 is offline   Reply With Quote
Old 04-08-2010, 12:04 PM   #11
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
What does the tube-in-the-tube actually do? Did they hear we like whistling, so they put a tube in our tube so we can whistle while we whistle, dawg?
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 04-08-2010, 02:54 PM   #12
jtragolia
Here is the E-mail conversation I had with Injen....
(E-mail to Injen)
I recently purchased and installed the Injen Cold Air Intake. Since the first day I've noticed an actual whistling sound while accelerating. I've had a cold air intake on my previous two vehicles and never heard this type of noise before. Additionally, I had an Air Aid cold air intake on this Camaro before I bought your product, and never noticed this type of noise. It isn't the sound of air being pulled into the filter it is definetly a whistling sound. Any ideas on what could be causing this? Maybe the tube inside the tube, as shown in the attached picture) Apparently it is common noise since some other members on Camaro5.com have noticed this too. Any info would be greatly appreciated.
Thanks,
Joe Ragolia
(E-mail from Injen)
Good morning Joe,
Thank you for bringing this to my attention. I believe you might have called yesterday and after speaking with Natalie (Injen customer service) regarding your issue, I had the original test vehicle brought in and we inspected it for any odd or abnormal whistling sounds. The only sound I heard was when you slightly press the accelerator pedal. There was an audible hissing/whistle sound. This sound is usually audible when installing a free flowing intake system due to removing all the factory muffler/resonator chambers and the restrictive air box. Normally the sound comes from the idle air control valve solenoid or when the air passes through the throttle body plate when it is slightly open causing the air to whistle. The tube inside the tube is called our Air Fusion tuning process which is now used in 90% of our intake that we design. This would not cause the intake to whistle. Are you 100% sure that the Airaid intake didn’t whistle? Is the sound unbearable? Does the sound affect the performance of the intake system? Do you have any check engine light? Hopefully it’s just the common hissing/whistling sound that is affiliated with most aftermarket intake systems.
Regards,
Paul Ho
Head of Research & Product Development
paul_ho@injen.com
(E-mail to Injen)
Thanks for the quick response, I was the one who called yesterday and spoke with Natalie. I’m 99.99% sure that the Air Aid intake didn’t make a whistling noise. I also haven’t noticed anyone posting anything about the Air Aid making a whistling noise on the forum. The sound isn’t unbearable, but it does catch my attention and the attention of other members on the forum who have it installed. I’ve noticed it especially around the 2500 rpm range. The check engine light has not come on, and there is a noticeable improvement in performance. It seems to be a very high quality intake. I just figured I would check with you guys to see if there was a feasible solution to the whistling noise.
Thanks,
Joe Ragolia
Old 04-08-2010, 03:25 PM   #13
scrming
scrming's Avatar
(E-mail to Injen)
Thanks,
Joe Ragolia
(E-mail from Injen)
Good morning Joe,
Regards,
Paul Ho
paul_ho@injen.com
The whistle is probably there then on the Airaid but I'm wondering if the heavier plastic tubing and the fact the Airaid has a sealed box and it just simply dampens the whistle..
Old 04-08-2010, 03:26 PM   #14
D Vegas
D Vegas's Avatar
haha im not as dumb as im told!! (not on the forms, you guys are the best!)
Fastlane Pipeline Cold Air Intake at Phastek Performance Jason@Phastek V8 Bolt-Ons & Tunes 2 03-30-2016 08:19 AM
Injen V6 true cold air intake bng804 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 384 11-03-2011 07:26 AM
aFe Stage 2 Cold Air Intake NOW SHIPPING from ECSpeedSound! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 44 11-13-2010 04:45 PM
K&N TYPHOON Air Intake Kit - On Sale ~ Bolt on 18+hp! Circuit Motorsports V8 Bolt-Ons & Tunes 101 02-06-2010 01:16 AM
Stealth Performance--Airaid Cold Air Intake GROUP BUY!!--Great Deal Torchdvette V8 Bolt-Ons & Tunes 140 11-01-2009 07:18 PM
