Old 04-09-2010, 06:24 PM   #1
Ukd73
Drives: 2010 1ss/rs Ls3
TRACTION CONTROL COMPETITIVE MODE?
I found out today if you push the traction control twice it has a competitive mode. Does every already know this and how is it different from turning it completely off? Did I miss something, dont remember it in the manual but I probably skipped it. I have TheLs3 manual tranny.
Ukd73 is offline   Reply With Quote
Old 04-09-2010, 06:33 PM   #2
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
yep, pretty much everyone knows this. Pressing the button once turns off traction control, allowing you to slip and spin wheels more freely and not "wheel hop". Pressing it twice engages the competitive mode (or launch control) which when you have it in 1st, clutch in, accelerator to the floor, the computer will set your rpm's at a predetermined rate (4K rpm) and when you dump the clutch, signals are sent to the engine's computer from your rear wheels to help reduce spinning. But in most tests, a good driver can perform a better launch manually. hope this helps. you should try it, it's fun on a closed course of course
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 06-02-2020 01:51 PM
Who's Tested Traction Control and StabiliTrack Duke 5th Gen Camaro SS LS LT General Discussions 15 12-07-2009 09:00 PM
Competitive Mode DevilKnightFalcon Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 20 11-02-2009 05:51 PM
COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 80 05-02-2009 01:20 PM
Traction Control Stabilitrac BUMBLEBEE_SS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 04-04-2009 10:55 AM
