Old 04-10-2010, 02:51 PM   #1
mtm864
Drives: 2010 2SS/RS
410 question
thinking of going to the 410 setup on the ss i dont think ill need the full install kit just some shims (but for what rear end?) and a new crush sleeve (from GM). what would i need to do as far as speedometer correction and also where can i order the gear sets from? thanks
10 2SS: LM1, K&N drop in. SOLD
14 2SS: stock...ish
mtm864 is offline   Reply With Quote
Old 04-10-2010, 05:55 PM   #2
Jason@Phastek
Jason@Phastek's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek
mtm864,
Since the car is so new you could get away reusing the existing bearings and races depending on how they look when you take the rear end apart. You could most likely reuse the same pinion shim once you pull the pinion bearing off. If you do damage the pinion bearing when pulling it off you could just get the pt# off the back of the bearing and get one from a local Auto Parts store. The only thing that you would really need would be Carrier Shims depending on how the backlash sets up. For the rest of the parts I would recommend going with the Richmond half kit which comes with Pinion Seal, Rear Cover Seal, new Ring Gear bolts, and Crush Sleeve. The speedo can be corrected by using a handheld programmer from either Hypertech or Diablo. You can also have it adjusted by someone using aftermarket tuning (HP Tuners, EFI Live, SCT, Diablo).
Hope this helps
Jason@Phastek is offline   Reply With Quote
Old 04-13-2010, 08:04 AM   #3
mtm864
Drives: 2010 2SS/RS
Thanks a ton i will look into the programmers does anyone make one that i can flash it back to stock and the dealer not know?
14 2SS: stock...ish
Old 06-14-2010, 09:26 PM   #4
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Hyper I have one of your products and would like the info you sent via PM as well
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Question re: c.i. displacement and hp Arli 5th Gen Camaro SS LS LT General Discussions 6 03-24-2009 02:20 PM
Bored so Ill ask a speculation question :) BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 13 02-12-2009 12:16 PM
Ready to place my order this week - One Question BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 9 01-21-2009 10:20 PM
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 10:06 PM
