Old 04-12-2010, 02:19 AM   #1
zerox
zerox's Avatar
Drives: 2010 2SS RS Bumblebee
Well I guess Splash Guards are going on
Camaro is almost 2 weeks old, put on 1150 kilometers and loving every minute of it. After giving the car a nice long wax job I noticed some unpleasent stone chips. I have about 3 small ones on the inside of the drivers side rear panel, 2 on the gills, and 1 decent, but not to big chip on the front bumper :( I have to bite the bullet and get the splash guards, I don't care much for the looks of them but I'd rather have that then getting all these chips. I never thought the paint was this thin, I hardly drove it on any "rough" roads and I avoided any gravel looking road. I guess it's just bound to happen. I am also considering getting my front bumper 3M clear braed. My question about the guards are
Do they need to be drilled in? Or can they just fit in? I never looked to see if there was pre drilled holes there, I'd much rather not have to start drilling holes in it as I will want to take the guards off If it's simple enough. And do they come in sets of 2 or 4? I hope you don't have to buy them in pairs.
zerox is offline   Reply With Quote
Old 04-12-2010, 03:52 AM   #2
revron
revron's Avatar
Drives: camaro 2lt rs auto silver
They come as a set of 4.
As I recall they attach with 2 pre drilled holes in the wheel well and you drill 1 hole along the bottom of the fender. Hardware and directions are incl.
Front fenders just turn the wheels to make room to be able to get at the screws. Back tires I took 1 wheel off at a time, but you might be able to do it with them on. It was easy to do and they help alot.
Ron
revron is offline   Reply With Quote
Old 04-12-2010, 04:01 AM   #3
drhoades
Drives: 2010 2SS
I put mine on just using the factory pre drilled holes and the included adhesive pad. I didn't feel the need to start drilling on the car. I was able to do it without removing any of the tires. I just used a small socket with a screw driver bit in it.
drhoades is offline   Reply With Quote
Old 04-12-2010, 05:25 AM   #4
jmelchio
SSmokinJoe
jmelchio's Avatar
Drives: 2010 SIM 1SS/RS M6
Take a look at this product. I just ordered a set of these, since they look alot more subtle than the OEM ones. I'll post pictures of them installed once I get them.
http://www.camaro5.com/forums/showthread.php?t=75660
1SS/RS Silver with Black Rally Stripes.
35% Tint
Roto-Fab CAI
SLP Loudmouth II Axleback
Hurst Shifter
R1Concepts Slotted Rotors
Hawk Ceramic Brakepads
I drive way too fast to worry about my cholesterol.
jmelchio is offline   Reply With Quote
Old 04-12-2010, 11:42 AM   #5
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
Super easy install, as Revron said, it comes in 4 (2 front & 2 backs) painted to your body color. You do need to drill 1 hole into the plastic wheel well and 1 screw (optional) into the bottom of the fender. They do come with pre-applied double stick tape, otherwise they utilize your pre-existing holes and screws. I was really against the splash guards till I got a scratch in my rear fender, since then, no more scratches and you don't hear sand being kicked up as much : )
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 04-12-2010, 12:27 PM   #6
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Yep, its an easy install. I took each wheel off just to make it a little easier. The GM splash guards fit very well, and (I think) look pretty good. I did go ahead and drill the holes (about six I think) just to make sure stay tightly fitted to the curves of the car.
Old 04-12-2010, 12:48 PM   #7
Ladyz28
Ladyz28's Avatar
Drives: 2010 RJT 2SS/RS, 2001 Ford Focus
You can put them on as stated above with the tires on and a small socket and bit. I chose to take the tires off and give the inside of the rims a good cleaning though. It was alot easier putting them on without the tires in the way.....
Ladyz28 is offline   Reply With Quote
Old 12-04-2010, 10:21 AM   #8
Powerjunkie
Drives: 2010 2SS/RS ABM
mud flaps
Has anyone seen factory mud flaps for$150? All I see is 4 for around $300
Powerjunkie is offline   Reply With Quote
Old 12-04-2010, 12:16 PM   #9
UHP-CAMARO
UHP-CAMARO's Avatar
Drives: Traded this for a 2013 ZL1
http://www.chevypartsplus.com/index....page=2&sort=2a
$159.20 Before shipping.
UHP-CAMARO is offline   Reply With Quote
Old 12-04-2010, 12:38 PM   #10
montreal2010yellow
montreal2010yellow's Avatar
I got some installed and no more chips since. The drilling, 1 per guard is into the plastic part of the car so no risk of corrosion in the future. They ca be taken off if ever you want to ilstall side skirts, but as far as i'm concerned, it's a must to keep the car spotles, also, the car soes'nt get dirty as much when it goes through some water on the roadé Cheap, 200$ at the most.
Old 12-04-2010, 12:48 PM   #11
I like the way they look
Old 12-04-2010, 01:37 PM   #12
panther2469
I do too
Old 12-04-2010, 01:58 PM   #13
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
I'm thinking of going with black splash guards with my victory red. Anyone else do this? Thinking it would go with the custom paint I have.
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 12-04-2010, 02:50 PM   #14
montreal2010yellow
i agree.
Has anyone installed the GM splash guards? clg_98ta Cosmetics and Lighting Modification Discussions 7 03-19-2010 12:11 PM
CGM w/ LS7 Front/Rear Blackout and Splash Guards LittleRockCGM Camaro Photos | Spyshots | Video | Media Gallery 25 02-21-2010 09:00 PM
splash guards red396 Cosmetics and Lighting Modification Discussions 2 02-04-2010 08:15 PM
splash guards paint chipping? milkman#1 5th Gen Camaro SS LS LT General Discussions 0 01-31-2010 06:43 PM
