04-12-2010, 11:01 AM | #1 |
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R Join Date: May 2008
Gears
Alright guys, I want to change out my stock gears for something like 3.73s.
Any recommended manufacturers? Does anyone know how hard the process is, is it an easier swap or one of the more difficult ones? Time? Thanks!
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer) 3000(accepted to production ): 4/19/09 3300 (scheduled for prod ): 5/11/09 3400 (broadcast ): 5/16/09 3800 (produced ): 5/22/09 4150 (invoiced ): 6/01/09 4200 (shipped ): 6/01/09 5000 (at dealer ): 6/12/09 6000 (delivery to me ): 6/12/09 |
04-12-2010, 11:21 AM | #2 |
Drives: 2010 LSX Shootout World AM Finalist Join Date: Sep 2009
this is deff not a do it your self job unless you have experience setting up the gears
the only 2 manufactures that i know of that have gears available are lingenfelter and richmond we use richmond if you want i can get you a price on parts i would love to do the whole job for ya but seeing as far away as i am its not very practical but i can get you a good deal on the parts |
04-12-2010, 11:22 AM | #3 |
Drives: '69 SS Convertible Join Date: May 2009
Richmond makes a set now.
Go with 4.10 though. Search the threads you'll see that everyone is really liking that gear. Also....be prepared for some sticker shock. You'll be looking at around $1,400 to have someone buy them and put them in. You'll probably want to change out your rear end bushings while you're there because most of the labor on that is going to be to get the rear end out. Keep researching.
Build Journal |
04-12-2010, 11:34 AM | #4 | |
04-12-2010, 11:48 AM | #5 |
It supposed to get ride of a bunch of wheel hop. I'll have to see if I can find the treads for you. Or....go search in the suspension section. That's where most of this stuff is located.
Build Journal |
04-12-2010, 11:52 AM | #6 |
Changing the gearing will create wheel hop? I upgraded some suspension stuff already and have no wheel hop whatsoever right now.
04-12-2010, 12:09 PM | #7 |
Drives: Everywhere Join Date: Jun 2008
Its done to get rid of the flex of the differential.
04-12-2010, 02:35 PM | #8 |
Plastic Cuttin' Badass
Drives: '08 G8GT 6.0 Join Date: Mar 2009
I have a G8, so it's not exactly the same as your Camaro. Your tires are a bit taller.
I have a 3.70 diff in my car now and I love it. If I were you, I'd look at 3.90s.
'08 Black on Black G8GT--> 12.166 @ 113.13, 1.723-60'<-before the gears...
FasterProms Tune, Ported TB/Intake - HSRK - Vararam - SLP 25% UD Pulley - ARH 1 3/4" Longtubes - Pypes Violators - Yank 3200 Converter - PCM4Less Trans Cooler - DashHawk - All Pedders Bushings, Xa Coil-Overs - Spohn Arms - Billet Prototypes Catch Can - Skinnies on GTO rims - ET Streets on F Body Rims - SJM LineLoc - 3.70gears/Harrop TrueTrac Coming Soon: Ported Heads/Cam/DoD Delete |
04-12-2010, 06:30 PM | #9 |
Drives: 2010 IOM 2SS/RS Join Date: Jan 2010
+1 for 4.10's
I know that seems like a lot of gear but keep in mind that you'll still get around 35mph in first and 125mph in 4th. In my opinion that is perfect. The stock tires are 28" tall and eat up more gear than you'd think. Just my .02 |
04-12-2010, 10:33 PM | #10 | |
My car is shifting at 20mph (approx 6300rpm) on the 1-2 at WOT with a 26.7" tire and 3.70s.
04-13-2010, 07:26 AM | #11 |
04-13-2010, 10:29 AM | #12 |
1st in the A6 is 4.03
04-13-2010, 11:40 AM | #13 |
Good point that wouldn't agree with 4.10's
Similar Threads | ||||
Lowering springs and rear gears V6 information | macwest | 5th Gen Camaro SS LS LT General Discussions | 12 | 04-30-2010 10:58 PM |
Richmond Gears V8 and V6 - Group Buy | ZZcamaro | Transmission / Driveline | 175 | 04-30-2010 12:29 AM |
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios | tbyrne | Transmission / Driveline | 9 | 01-11-2010 10:36 AM |
Motive Gears says no Camaro Gears | ZZcamaro | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 60 | 01-07-2010 02:47 PM |
PRI Update on Camaro Gears | Roger Ramjet | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 01-06-2010 08:08 AM |
