Old 04-13-2010, 12:35 AM   #1
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Tire Pressure Issues
Hi guys,
I have a problem with my new Camaro. I have a 1LT, with Stock 18inch wheels. The problem is, every 3-4 days, the tire pressure goes down 4 kPa, i think its like 2 psi?
Is that normal? I'm concerned. All 4 tires lose pressure at the same rate. The tire on the Steering wheel side is always the lowest in pressure. I have pumped my tires back to the Required pressure, but it drops again every 3-4 days.
If this is normal then, phew... but otherwise, anyone have this problem? Should i just call my dealer and get it checked out?
Thanks in advance.
jagan323 is offline   Reply With Quote
Old 04-13-2010, 12:49 AM   #2
HALFFAST
HALFFAST's Avatar
Drives: 2010 Chevy Camaro
are you always checking under same conditions? Your tire pressure will always be significantly higher when they heat up while driving versus when cooled down parked for an extended period. It is not normal to need air every few days
it's my shell I'm the turtle
HALFFAST is offline   Reply With Quote
Old 04-13-2010, 12:56 AM   #3
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
My car was doing the same thing. I took it to the dealer and their tire technician worked on it. I'm not quite sure what he did (not gas) but I haven't had a problem for @ 4 months. I just got a notice that my pressure was low but the weather's changin so...
Chevyg1rl is offline   Reply With Quote
Old 04-13-2010, 01:12 AM   #4
jagan323
I have no life
jagan323's Avatar
I keep checking the tire pressures around the same time, and it's always when I just start the car in the morning. I suppose temperature can cause spikes, but the pressure is always lowering, never going up... I guess I'll have to call Tech.
Thanks guys
Old 04-13-2010, 07:31 AM   #5
nosrettap58
nosrettap58
nosrettap58's Avatar
Drives: 2023 Camaro 2SS Convertible
Put nitrogen in them instead of air. Pressures fluctuate alot with O2
nosrettap58 is offline   Reply With Quote
Old 04-13-2010, 08:01 AM   #6
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Every time you drive your tire pressure builds up quite a bit because the heat buildup of the rubber in the tires. This also causes the molecules in the rubber to enlarge causing the slight escapment of air between them, when it cools back down then your pressure will read a little lower than it did before. Like someone else stated if you put Nitrogen in them then the pressure won't build up as much and If I remember correctly Nitrogen molecules are larger than oxygen and will result less loss of pressure from heat cycling... Although Air is part Nitrogen there is not enough volume to make much difference, so pure Nitrogen is the way to go unless you want to keep close watch on your air pressures...
The Bird is the word!
Old 04-13-2010, 08:09 AM   #7
VR Code R6P
Drives: 2011 Race Red GT500 w/ SVT Perf Pkg
The pressure will fluctuate with temperature no matter what, air is 78% Nitrogen. 100% dry Nitrogen may be a "little" better.
It will make a difference what side the sun is coming from, and which tires are exposed to it's rays. Maybe that is why you are seeing a difference between the tires, if it is parked outside.
Tire pressures should always be checked before being heated up from driving, or sunlight.
VR Code R6P is offline   Reply With Quote
Old 04-13-2010, 08:10 AM   #8
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
You are supposed to check your tires when they are cold before you drive the car. The press will go up during driving because of heat.
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 04-13-2010, 08:10 AM   #9
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 04-13-2010, 08:11 AM   #10
Lazerbrainz2k3
Drives: 2017 Camaro 2SS - M6, NPP, MRC
I've had the same problem, but only with one tire. The other three seem to change pressure in unison, as does this one usually, but every now and then (1-2 week intervals) the one tire goes down 4-5 psi. I jacked it up, put a big pan of water under it and rotated the wheel, looking for bubbles, but no such luck. Gave it a visual inspection, didn't see anything. Weird... I can see all of them going down, or some random thing, but the same one again and again?
Guess I may need to have mine looked at, too.
Lazerbrainz2k3 is offline   Reply With Quote
Old 04-13-2010, 08:19 AM   #11
ron10
Drives: 2010 2SS IOM L99
don't check your tires for a few days,to see if your tires are actually losing air.
if you indeed are losing presure,it has to be the rims or valve stems.
Old 04-13-2010, 09:03 AM   #12
jagan323
I have no life
jagan323's Avatar
Okay, i'll have all those issues checked =/ Thanks alot for the info and advance guys
Old 04-13-2010, 09:10 AM   #13
JerseyMonte
JerseyMonte's Avatar
Drives: 1972 Z28
Hard to judge real pressure
My pressure shows 36psi cold [recomended]
after they warm up it goes to 45psi, but remains
constant.
JerseyMonte is offline   Reply With Quote
Old 04-13-2010, 09:15 AM   #14
TooCool5
TooCool5's Avatar
My Heritage Steel wheels do not leak a bit of air, in fact I had to take some air out when it got warm out this spring.
One of the reasons I like steel, that and strength, ALL my other cars with alloys leak air.
Bad Tire Pressure Monitor System DkknightX Wheels and Tires Talk Sponsored by The Tire Rack 29 07-30-2010 06:24 PM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 08:04 PM
Tire Pressure Monitor Help noisemker Wheels and Tires Talk Sponsored by The Tire Rack 0 01-04-2010 10:23 PM
tire pressure monitoring system and cold weather RealQuickCamaro General Automotive + Other Cars Discussion 3 01-04-2010 11:54 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 03:42 PM
