Old 04-13-2010, 09:24 AM   #1
chrislhardin
Kalel7
chrislhardin's Avatar
Drives: 2010 Camaro LT2 Victory Red
Adhesive that won't ruin my paint, gill strips
One of my gill strips I installed Sat is coming up a bit and I want to stick it back down, does anyone have a recommendation of some glue I can put behind it to restick it or do I just need to remove it and retape that back of it? I don't want to put anything that might ruin my paint.
chrislhardin is offline   Reply With Quote
Old 04-13-2010, 09:31 AM   #2
Russell James
Russell James's Avatar
I would contact the vendor and get another piece.
Old 04-13-2010, 09:43 AM   #3
highmark
Burnin out!
highmark's Avatar
Drives: Sick SS
Same thing happened to me. I tried everything to glue it back down. After no sucess I got a hair dryer and took it off It came off really easy with minimal tape left on vehicle. Needed to scrape off old 3m and add a new strip. The trick is to bend the gillss slightly so they dont want to bend outward. Good luck.
highmark is offline   Reply With Quote
Old 04-13-2010, 11:04 AM   #4
j0hnny007
j0hnny007's Avatar
Drives: 2010 2SS RS
the trick is to put them on with a heat gun and 15 lbs pressure so u get full wet out of the 3m tape, also when you clean the area before u put them on make sure you do not use a petroleum based cleaning product cause the tape will not adhere to a surface with residue from petroleum based cleaners. You can use 3M general purpose cleaner part number 08984 if a strong cleaner is needed.
hope this helps
j0hnny007 is offline   Reply With Quote
Got my Zaino today lordfriday2 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 261 05-31-2014 11:00 PM
Paint your own stripes? blackZbandit Cosmetics and Lighting Modification Discussions 44 09-18-2011 10:22 AM
The Official Thread about Custom Paint! pinkcamaro10 Cosmetics and Lighting Modification Discussions 30 03-28-2009 08:17 PM
door handles camarokidz28 5th Gen Camaro SS LS LT General Discussions 32 06-08-2008 10:15 PM
