Old 04-13-2010, 08:29 PM   #1
Jayhawk500
Jayhawk500's Avatar
Drives: 2010 Camaro SS/RS
Front Horn Mounts for Vararam intake
This is a simple fix to a solution I couldn't figure out using Vararams 6" bolts. After seeing HeavyChevy's pictures I know understand how the bolts were used. But personally it doesn't look too sturdy.
I used a 5" vice, a #2 phillips screwdriver, a ballpeen hammer and a pair of vice grips.
I went to Home Depot and purchased a round plain steel rod from the hardware dept, 3/16" x36". This is a mild steel and will bend without having to heat it up.
Follow Vararams directions on installing the intake.
I started by inserting the end of the rod into the vice to a depth of 7/8". 1" will work though. Using the large ballpeen hammer bend the rod at a sharp 90 degree angle to the front of the vice.
Remove the rod from the vice, and mount the screwdriver in the vice with the tip up.
Wrapped the bent portion of the rod around the screwdriver until it's 180 degrees from where you started. There should be a gap large enough of the OEM bolt.
Insert the "U" shaped portion of the rod into the vice until the bitter end is flush with the top of the vice. Now bend the rod towards the front of the vice to a 90 degree angle using the ballpeen hammer.
At this point I cut the rod with a hacksaw to a length of 2 1/4".
Using the intake, and putting the rod in position on the radiator support, I saw where the rod started to leave the intake, and started to bend the rod down in small sections as to completely make contact with the horn. When finished this should be a complete 90 degree angle. There will be some tweaking you might have to do, but all-in-all you should get a tight fit.
You have to remember, to wiggle the radiator and make sure the intake is fully seated down on the supplied supports while checking, when bending the rod.
Make the second mount the same way but reverse the bend so the bitter end is towards the outside of the car.
I then sandblasted the rods, primed, and painted with engine paint.
I hope this helps!
The last picture is of the PCV line. I went to my local NAPA store and purchased a length of 1/2" o.d. plastic airbrake line. The inside diameter is 3/8 ". I also got a plastic 90 degree 3/8" barbed elbow for the intake. Make sure to route the hose away from the idler pulley. If you don't you will throw a code from bubbing a hole in the hose. Please don't ask me how I know.
I have a RevXtreme catchcan in route so I should be installing it soon.
Jayhawk500
2010 2SS/RS, Six speed, Rally Yellow w/ Black Painted Stripes, Boston Acoustic Stereo, Polished 20" wheels, Solo Mach X Catback Exhaust, Solo HF Cats, Halltech CAI, Full Dash & Door ABL, ABL Lit Homelink Buttons, HUD Installed, Ride Tunes, Full Electric Passenger Seat, Fbodfather signed, VIN # 4492, PAID OFF!!!
2010 Yellow 2SS/RS with black painted Stripes...$37,000.00; Ride Tones sound system and remote...$ 40.00; Seeing the kids faces (Young and Old) light up and almost wet their pants....Priceless!!!
Jayhawk500 is offline   Reply With Quote
Old 04-13-2010, 09:27 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Send a message via AIM to BigMatt
can you take some pics a little zoomed out so I can see exactly what I'm looking at? Nice work though
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 04-13-2010, 10:13 PM   #3
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
That looks good but it does not secure the radiator
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 04-13-2010, 10:17 PM   #4
Jayhawk500
Jayhawk500's Avatar
If you use the rubber spacers that were supplied with the intake and put them in the proper places. These mounts do hold the radiator solidly in place. There is no movement at all, in the radiator or intake.
Jayhawk500
Old 04-13-2010, 10:20 PM   #5
Jayhawk500
Jayhawk500's Avatar
Third picture is looking somewhat forward on the passenger side.
Fourth picture is looking somewhat forward on the drivers side.
Fifth picture looking from passenger side to the drivers.
Pictures will follow tomorrow.
Jayhawk500
Old 04-13-2010, 10:42 PM   #6
Jeanius
Jeanius's Avatar
Ah!
You should sell these!
Group Buy anyone???
TRADED: 2016 2SS M6
Old 04-14-2010, 07:49 AM   #7
1camaro70
1camaro70's Avatar
Drives: 2010 2SS RS L99
Great idea, the way the intake fits over the radiator, this should secure everything, should have Vararam use this idea, and compensate you for it.
1camaro70 is offline   Reply With Quote
Old 04-15-2010, 08:14 PM   #8
Jayhawk500
Jayhawk500's Avatar
Naaaa, I would just like to get my receipt.
Anyone with mechanical ablitiy can do this.
Jayhawk500
Old 04-15-2010, 08:16 PM   #9
Jayhawk500
Jayhawk500's Avatar
Ah!
Group Buy anyone???
It would take less than 5 minutes to make if there was a jig.
Although, Thank You for the compliment. I'm not in that kind of business. I just want you all to now how to fix a small problem.
If someone truely is having difficulty. PM me and I'll hook you up.
Jayhawk500
Old 04-19-2010, 10:47 PM   #10
Jayhawk500
Jayhawk500's Avatar
Here's the pictures. Sorry it took so long.
Jayhawk500
Old 11-09-2016, 08:10 PM   #11
SabsBee
Transforming
SabsBee's Avatar
Drives: Transformer Edition Camaro
Sorry, I'm late to the party but I just installed mine. I'm curious what is holding the radiator. The vararam set up has the anchors on the radiator while yours is just holding the vararam. What is securing the radiator?
Rick P
Dual Masters in Special and General Ed
Camaros because they have the personality you design.
SabsBee is offline   Reply With Quote
Old 11-09-2016, 08:57 PM   #12
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
That's a good idea.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
CAMARO WIKI Tran Wiki 67 11-27-2024 08:02 AM
Scrming's Air Intake Experiment - Part II scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 94 05-02-2010 03:56 AM
1SS standard equipment and options Tran Wiki 1 11-05-2008 02:34 PM
1LS standard equipment and options Tran Wiki 0 10-18-2008 08:13 PM
