LSR Performance Shifter Install
Got my shifter yesterday and all I can say it is a huge difference for the better.
First off, special thanks to TAG UR IT for an extremely detailed post with photos and videos. Have a couple of additional tips. On the spring clips I used a bent nose needle nose pliers, makes it easy. You only need to remove the driver side spring clip. Twist the shifter/fork assembly towards the passenger side slightly, and slide the pin out. Here are a few photos. LSR Performance Shifter exploded view LSR Performance Shifter Assembled LSR Performance Shifter vs Stock Shifter Bent Nose Needle Nose Pliers Shifter lower installed with boot Upper shifter installed. You can see two of the four adjustment holes. I have it set for 33%. The top hole is for the lock screw. Shifter boot groove, height adjustment and shifter ball lock nut. Shifter ball installed working on height adjustment. All buttoned up. I ended up going up one slot on the adjustment. (front) so I'm at about 29% reduction. Final view. I love the reduction and the look is fantastic. ZooDad
2010 Camaro 2SS/RS - Summit White
K&N 63-3074 LSR Performance Tri-Ax Shifter Eibach Pro Kit - Springs |
PWA Relapse
Very nice! Congrats.
- X
2017 1LT/RS A8 Hyper Blue Metallic |
![]() ![]() ![]() Drives: none Join Date: Oct 2009
I'm glad you are happy. Happy shifting.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
Great write up and pics.
1968 Camaro Convertible LS1, T56
Btw great write up.
#6 |
Frog
I completely agree the LSR shifter makes huge improvement in shift feel. The shifter was the first modification I did to my car. Their other parts they developed for the camaro ( swaybars and frame braces) that I bought from them are fantastic too. Top quality products an staff real friendly and helpful. I say u can look to see some of the best quality products coming from this company
I'm not speeding....
.... I'm qualifying ![]() IYAAYAS |
#7 |
Thanks for the kind words Becca. I'm glad that you are really enjoying your lsr products on your camaro.
#8 |
Small bump
#9 |
![]() Drives: 2010 Chevrolet Camaro 2SS/RS Join Date: Mar 2010
I installed mine this weekend...Reverse is hard to get into but 1-6 works great...Any ideas why Reverse is so hard to get into?
*Cyber Grey Metallic 2012 Chevrolet Volt
*Black 2010 Victory Cross Country *Black 2008 Chevrolet Corvette 1LT/NPP/Z51/M6 *Black 2007 Dodge Charger SRT8 *Black 2005 Yamaha R6 (Raven color) *Black 2010 Chevrolet Camaro 2SS/RS/M6 (SOLD) *Black 2003 Dodge Neon SRT4 (SOLD) *Inca Gold 2002 Chrysler Prowler(SOLD) |
#10 |
How short is the throw you have it. Also where is the position of the ball height? When you have everything at the least amount of throw you will have less leverage to shift. Which in turn makes it harder to go into the far gears. Pm me for more information or email me at aldo@lsrperformance.com Thanks
#11 |
looks awesome
#12 | |
I have the adjustment screw set to the lowest setting...Only Reverse is hard, all of the other gears are easy to get into...Everything installed without issues as per the manual (square round seal, cage, 2 bottom bolts with retaining ring, the pin & clips, and the rubber cover.
What is hard is moving the shifter to the far right past 5th and 6th...pushing to get into reverse is not too hard but harder than the other gears. (5th and 6th are fine though) Quote:
#13 |
![]() Drives: me up the wall. Join Date: Dec 2009
I like mine.
Getting the bottom dust boot back on was a real challenge though! Also, I've noticed that you need to make sure you really push the stick forward for positive engagement in 1st, else-wise it may pop out of gear with a startling 'Pop' followed by a revving engine, burning clutch smell and a rather loud "Oh $h1t!" ... and reverse too. Not blaming the product; it's more like operator error. |
#14 |
rmnc3r it happens even to the best of us lol.
cplabaunza im looking into this for you. |
| MGW Shifter Install | SSRSLY | Camaro DIY & HOW-TO instructions & discussions | 17 | 06-04-2016 09:45 PM |
| TAG's 2010 THRSS #2 | TAG UR IT | Member Car Journals | 3129 | 08-14-2014 09:29 AM |
| NEW ITEM: LSR Performance Short Throw Shifter | larry@lsr | Transmission / Driveline | 68 | 08-31-2010 08:06 AM |
| LSR Performance Intake = BIG POWER!! | Meister@Torq | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 76 | 06-29-2010 08:06 AM |
| The BEST upgrade for your new Camaro - Camaro Six Shooter shifter | MTI Racing | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 19 | 07-23-2009 02:52 PM |
