Outlaw
Drives: 2010SS Join Date: Jan 2009
Did the LSX kill the big block?
So I've just read the LSX (iron small block) can be bored and stroked to reach 511 cubic inches.
I've been dreaming of the COPO ZL1 427 all aluminum big block Anniversary Edition - about 20k http://www.autoblog.com/2007/11/02/l...oming-from-gm/ Similar motor, ZZ 427 Crate costs half that (iron block) http://www.jegs.com/i/GM+Performance...66393/10002/-1 Given the scalability of the LSX, is there any reason one would buy a big block, either for cost, weight, power potential, or reliability? and What is the cubic inch limit of the LS3 in my car now? -at least 427 http://paceperformance.com/index.asp...&ProdID=239245 Last edited by BOBSS; 04-15-2010 at 12:00 AM. |
![]() ![]() Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
Not sure I can answer your question and what you want to do with the engine but the pics in your post are not LS type motors. Rather, they are old school big block from the past. Look at the water pumps on the front of the motor. Not sure I am answering your question but I do not see the LSX in any of these motors. Not sure of the CI limits of the LSX engine but I have a 440 CI LS-7 motor in my TBSS. Not sure about 510 CI LSX. Maybe I am wrong.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
just can't seem to leave
dinosaurs used distributors...
Eve ('00 FRC): hot-air intake
Rowan ('09 H3): 5spd mom-mobile Penny ('99 Sierra): 5.3 / HD 5spd... gone but not forgotten Samson ('18 HD): compounded 408 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
LSX = new kid on the block
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
![]() ![]() Drives: Everywhere Join Date: Jun 2008
Your LS3 can be made to produce the same power as the big blocks you posted above and still weigh much less. And yes GM LSX block can be made to 500+ cubes but your LS3 block is capable of the 427 mark with a 4.100" crank. A super flat torque curve is the only thing those engines have over yours and that could be duplicated with the right motor combination and/or a supercharger.
#6 |
400+rwhp and climbing!
I love the ls motors but, I also like the feel of a 1000+hp 600 ci BBC!!!
#7 |
^^ that's puuuurty
#8 |
![]() Drives: 11 2SS 6spd, 77 Trans Am, 13Audi Q7 Join Date: Apr 2010
LS's makes great street engines but for all out drag racing and power boats the big blocks are here to stay for quite a while. When a 500ci ls can make NHRA prostock power for several runs a year then maybe the tables will turn. IHRA prostock goes up to 815 or 825ci if I remember right. That is huge.
And if you want to talk about boost look at some of the cars in the pump gas drags or pump gas nationals. I am not sure of the name of the race. There are some HUGE displacement big blocks in heavy cars running lots of boost. They need to come out with a LSX big block!!! |
#9 | |
![]() Drives: 2010 SS M6 2016 2SS A8 Join Date: Oct 2009
TVS 2300 721RWHP 686RWTQ
Built by Me Suspension done by JDP Tune done by JRE |
#10 |
both definitely have their strong & weak points.
personally, if i'm pushin 500cid and runnin high boost, i would trust a big block to hold together much more than an LS. now when you start looking at special materials, that's a different story. i know a guy who's got a billet aluminum 440ci LS block (actually made by DART, not LSX) that he's gonna run a TVS blower on 18psi, if i remember right.
#11 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
We were just discussing this over lunch I just came off the dyno with a stock ls3 with a cam and blower that made 735 RWHP on pump gas that's 855 Crank HP on a Production engine.
Tony who works for me and raced with me for over 25 years said He is putting all his big block parts out for the garbage man LOL! The LS is NOW KING!!!
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#12 | |
![]() Drives: 1ss w/6spd Join Date: Jan 2010
#13 |
![]() Drives: 2010 SIM SS/RS, 1968 RS convertible Join Date: Sep 2008
It has proven that the LSX can handle 2000hp. Sounds like Warren Johnson knew what he was doing when he designed it with GM. Case closed.
![]() LSX ---> Z28
2010 SIM SS/RS see garage for mods
#14 |
i think it all depends on the car you are building, me personally i like retrofitting the ls and lsx small blocks into old muscle cars. but if i was to build something like a 55, 56 or 57 or even an old rat ride i would probably be going with a big block. also if you are restoring the car like it came off the show room floor then you want to go with type of motor the came with so if it came with a big block then you want a big block etc.
my youtube
my facebook www.myspace.com/1djchampagne www.twitter.com/1djchampagne mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune 750/641 rwhp/rwtq |
| 572 Big Block | Tomcat2010 | 4th Generation Camaros | 7 | 05-08-2015 10:44 PM |
| BIG RED - The WORLDS BADDEST CAMARO and its '69 Z/28 non the less (True Story) | NOODLESgoneWILD | 1st & 2nd Generation Camaros | 12 | 10-01-2014 10:15 AM |
| big block vs small block | jleinaweaver | General Automotive + Other Cars Discussion | 37 | 04-20-2010 12:55 AM |
| 408ci or 427ci, iron block or aluminum block | ls7camaro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 01-20-2010 08:59 PM |
| LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue | 13F20 | 5th Gen Camaro SS LS LT General Discussions | 15 | 09-22-2008 05:35 PM |
