Old 04-15-2010, 07:10 AM   #1
se7en
Drives: 10 Procharged SS
Widening the stock rims: Quotes needed
I'm looking into widening my stock front Rims from 8" to 10.5". I want to leave the rear ones at 9" as they will be going on the front.
Ive never had this done, but i have an idea on how it works after reading some threads on here.
Vendors, please send me PM with some quotes. Please send quotes with shipping to and from 62856.
If anyone can point me in the right direction it would be much appreciated.
se7en is offline   Reply With Quote
Old 04-15-2010, 08:29 AM   #2
600hp-lpe
Drives: 2010
Andy at ADM has some already done on the shelf. He does an exchange program.
I believe he sells them with/without pirelli tires to match what you have....
600hp-lpe is offline   Reply With Quote
Old 04-15-2010, 09:12 AM   #3
monstertodd
monstertodd's Avatar
PM Gary's custom's. AKA orange10s.c.
He does the same thing. Might be able to compare prices with ADM.
Old 04-15-2010, 12:04 PM   #4
se7en
Thanks 570!!
If you keep giving me all this advise on my Camaro i may have to start putting you on the advice payroll! I hope your prices are cheap! haha
Old 04-16-2010, 10:39 AM   #5
BLWN SS
BLWN SS's Avatar
Drives: Orange SS/RS W/ White Stripes
You can check with Weldcraft in Mo. i think or Vaughn Machining in southern Ca. They actually do the widening them selves. Just got my set back (rears) from Vaughn from being widened to 10 1/2" and put brand new 315 NT05R's on them (heat cycled) each wheel required less weight than the factory tire/wheel combo.
BLWN SS is offline   Reply With Quote
Old 05-04-2010, 10:52 PM   #6
LibLoather
LibLoather's Avatar
Drives: 2010 2SS/RS Summit White
BLWN SS, do you mind answering a few questions regarding Vaughn?
1) How long did it take them to complete your rims?
2) Did you have to install longer lug studs to accomodate the spacer?
3) Any problems with balance at higher speeds?
Thanks a bunch!
LibLoather is offline   Reply With Quote
Old 05-05-2010, 12:43 AM   #7
BLWN SS
BLWN SS's Avatar
Thanks a bunch!
No problem - It took about 2 weeks, he told me it would take 3. I used 1/4" spacers so did not need longer studs. The amount of weights required to balance the rims and new tires are about the same (or less) than are on my stock wheels & tires. I've ran up to about 120 mph in the quarter mile and they are very stable, no vibrations.
This is the first set I have had widened so I am no expert but I will say to me it looks like a very high quality job. The welds are picture perfect. I dont think anyone would be disappointed in their work. I have gotten a lot of positive comments at the track from people who have looked at them.
Old 05-05-2010, 08:17 AM   #8
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
"No problem - It took about 2 weeks, he told me it would take 3. I used 1/4" spacers so did not need longer studs. The amount of weights required to balance the rims and new tires are about the same (or less) than are on my stock wheels & tires. I've ran up to about 120 mph in the quarter mile and they are very stable, no vibrations. "
What 1/4" spacer did you use ???
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 05-05-2010, 08:30 AM   #9
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
weldcraft qouted me at 275/wheel. 3 week turnaround time. that's a LOT cheaper than the other places out there..
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 05-05-2010, 09:04 AM   #10
4SD FED
4SD FED's Avatar
Drives: 2010 rs/ss camaro
Weldcraft does good work, there about 30 min drive from me. I have not had them do any work for me but have seen there place
4SD FED is offline   Reply With Quote
3rd Gen Camaro Street Stock build thread (dialup beware) zlathim 3rd Generation Camaros 9 12-06-2018 11:30 AM
1/4 Mile Discussion Thread Camaro_Corvette Dragstrip and Launch Techniques Discussion 279 09-25-2014 09:49 PM
How big of a tire do you think you can put in the stock 9" wide rims? alex33x Wheels and Tires Talk Sponsored by The Tire Rack 3 04-12-2009 10:47 AM
RS rims/ Stock rims jclark5 Wheels and Tires Talk Sponsored by The Tire Rack 9 03-19-2009 08:51 PM
21" stock rims..... 2010_5thgen Wheels and Tires Talk Sponsored by The Tire Rack 67 10-04-2008 10:16 PM
