Old 04-15-2010, 10:52 PM   #1
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Removal of rear seat
How do I remove the rear seat? Can someone give me a step by step please?
Cheers
K
Moriartii is offline   Reply With Quote
Old 04-16-2010, 08:23 PM   #2
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Removing Rear Seat
1) There are 2 clips at the front of the seat, about center of the "bucket" portion, one on each side. Firmly lift the seat straight up. Push the seat belt latches through to the bottom of the seat.
2) The bottom portion will fold upward basically flush with the upper portion. It will spring back down so you have to hold it up there.
3) There is a large nut in the center you need to remove, 18mm deep socket.
4) At each corner there are 2 bolts to remove, the one on the bottom is easy to spot but there is one above it partially hidden. 15mm socket
5) Pull the loop to unlatch the upper portion and lift out. Be VERY mindful of the metal at the bottom of the seat to prevent harming your interior trim.
terry_b is offline   Reply With Quote
Old 04-17-2010, 04:39 PM   #3
Moriartii
Moriartii's Avatar
Thank you Terry_B!!!!!
I greatly appreciate that!
K
Old 06-20-2010, 07:57 PM   #4
firesquirt
firesquirt's Avatar
Drives: 2010 Camaro 1LT
anyone know how to remove the fron seats ?
firesquirt is offline   Reply With Quote
Old 06-21-2010, 12:04 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Move the seat forward all the way, Then fold the seat forward, There are 2 bolts to remove in the track at the rear of the seat, then all you do is lift and slide it back to remove the seat, Don't forget the electric connectors.
Old 06-21-2010, 12:10 PM   #6
purplhaizcraz3
Drives: 2010 2LT CHEVY CAMARO BABY!!!!
How much weight could be shaved off if you remove the rear seats and front passenger seat?
purplhaizcraz3 is offline   Reply With Quote
Old 11-11-2010, 10:47 AM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
BUMP.........anybody have these weights.......?? Looking to shave weight for some good runs at the 1/4 mile......
Old 11-11-2010, 11:37 AM   #8
rtcat600man
got the weights
As for the seats......
front seat from a 2LT trim with leather and electric can save ......aprox. 48 lbs.
rear seat bottom is another 12 lbs.
rear seat back is another 18 lbs
for a total seat removal of 78 lbs.......
Old 11-11-2010, 04:38 PM   #9
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Originally Posted by rtcat600man View Post
got the weights
Don't forget the back seat/seat belt anchor bracket, another 10 lbs there.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 11-11-2010, 08:13 PM   #10
rtcat600man
good call. If it to can be removed I will look into that too.
Thinking about the weight drop for next season once I get some drag radials and make an all out attempt at some good times. Gives me another good reason for the driver to drop his 100 lbs.
Old 11-11-2010, 08:27 PM   #11
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Easy to remove, 4 bolts and one nut. I saw some guy do it in about 2 minutes, he weighed it too!
Old 11-11-2010, 08:39 PM   #12
rtcat600man
That gets us to 88 lbs for the seats. Plus 100 lbs for the driver. Another 80 lbs for the gas (run on a 1/4 tank instead of full tank). Take out the wiper fluid bottle, another 6 to 8 lbs. remove the engine cover, trunk spare tire cover, mat, and air pump (all good for maybe another 8 - 10 lbs.) empty the glove box (maybe 2 lbs.)
All totaled for 284 lbs. Wroth approximately .3 seconds. That would defiantly get someone into the 13's.
Old 04-15-2012, 03:36 PM   #13
nick5400
nick5400's Avatar
Drives: 2012 1LS
I'm 2 years late to the party but I will say thanks for the info. I am installing custom fitted seat covers for my LS and it is almost IMPOSSIBLE to install them properly without removing the seats. Gracias Amigos!
nick5400 is offline   Reply With Quote
Old 06-08-2012, 12:16 PM   #14
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
This post is the post that just keeps on giving! Helped me a year ago and helped me again today... I think I may make a video of me removing the seats today
Cincy Speed Rear Diff Bushing Removal tool Qwkss Suspension / Chassis / Brakes 10 01-22-2012 11:36 AM
Removal of rear diffuser on v6 kellyjrt Cosmetics and Lighting Modification Discussions 3 02-03-2010 01:10 PM
No confirmation number? jamesc1123 Camaro Price | Ordering | Tracking | Dealers Discussions 12 02-21-2009 09:49 PM
Pricing/optioning guesstimate KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 156 02-24-2008 05:33 PM
