Old 04-19-2010, 05:58 PM   #1
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
BBK Shorty headers compared to stock manifolds
Hey guys, thought you would like to see these pictures of the BBK shorty headers compared to the stock exhaust manifolds.
The Collector Openings on the headers (which seem to be the biggest restriction in the stock manifolds) measure up like so:
Stock manifolds: 2.15 inches
BBK shorties: 2.52 inches
We will be doing an install with instructions as well, and will post that info soon.
Sean@Phastek is offline   Reply With Quote
Old 04-19-2010, 07:37 PM   #2
yota924x4
yota924x4's Avatar
Drives: 2010 Camaro SS m6, 1970 Nova SS396
Send a message via AIM to yota924x4
how about measurements of the primaries at the flange or the bbk's and stock manifolds while you have your verniers out? and or measurements of the ports on the heads themselves?
thanks
chris
yota924x4 is offline   Reply With Quote
Old 04-19-2010, 07:52 PM   #3
Sean@Phastek
The stock exhaust manifolds have an oval-shaped opening, the BBK's are more of a circle. I will get some good pics of the exhaust ports on the heads when we do the install.
PS - Nice Nova! I have a '69 going under the knife right now..
Old 04-19-2010, 07:54 PM   #4
Scrappy Doo
Scrappy Doo's Avatar
Drives: Callaway Rogue
How about a before and after dyno????
Scrappy Doo is offline   Reply With Quote
Old 04-19-2010, 09:07 PM   #5
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
It appears in the picture BBK supplied you with the 4 - 25mm long, M10-1.5 12 point bolts to attach the factory mid pipes to the headers. I found those bolts for BBK when I ran into trouble installing my BBK stainless Steel headers on my LS3. You will have to remove the factory studs from the mid pipes with an 8mm wrench if I remember correctly. The stock 15mm hex flange nuts and studs won't work to attach the mid pipes to the collectors , I know as I alerted BBK to the issue. The other thing to watch out for is the collector flanges aren't perfectly flat, however with the stock factory copper gasket and tightening the 4 mid pipe bolts down securely, there are no leaks. See my posts on BBK shorty headers. Other than that, headers fit fine. I have approximately 1500 miles on mine and they seemed to increase power in the 3k to 6.5K range and only slightly increased the sound level.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 04-20-2010, 08:33 PM   #6
Sean@Phastek
Ed M.
Those are pictures from our shop, right out of the box. This set arrived on 4/15 for reference... so probably left BBK around the 12th of April.
I tried to use the stock bolts for a test fit, and they do hit the collector flange on the BBK headers like yours did. Thanks for the heads up on that to BBK, saved us some time & work!
It seems like the stock collector flange gasket is thick enough to close up any gaps if the flange isn't perfectly flat... I will be keeping a close eye on this when we do our full install.
Old 04-21-2010, 06:50 AM   #7
flht99b
flht99b's Avatar
Unless BBK didn't update their instructions ( I suspect they have based on my conversations/emails to them ) you will need to disconnect and collapse the steering shaft to install the driver side header. I installed both headers from the bottom. I wonder if I should have gotten a consultant fee from BBK.........
Ed M.
Old 04-21-2010, 05:37 PM   #8
Scrappy Doo
Any word on a dyno test then????
Old 04-22-2010, 07:32 AM   #9
flht99b
flht99b's Avatar
I haven't had my car dyno'ed nor did I do a fuse pull after the header installation. After driving with them on my car nearly 1300 miles I can definitely say there is a seat of the pants increase in the 3K to 6.5K rpm range. I have and posted the dyno sheet BBK supplied me and it basically confirms what I've said. These headers will not make the larger power gains of long tube headers, but they do seem to make some power. I was interested in keeping my factory warranty so shorties were the only option. BBK was the only vendor offering shorties in T-304 stainless so they were my choice.
Ed M.
Old 04-22-2010, 08:41 PM   #10
Scrappy Doo
Ed M.
I want to see an "impartial" dyno sheet. One of the shops on here posted a sheet where shorties made less power than the stock manifolds. I want to get shorties to avoid the tune, but if they make 0 or no power, I am not wasting my money.
Old 04-24-2010, 03:19 AM   #11
flht99b
flht99b's Avatar
Bump for install and dyno results........
Old 04-24-2010, 03:43 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Someone is going to have to one with the stock cats too. TSP's test with the the stock cats. Replacing the cats with highflow ones is proven to give decent HP gains, even with the stock manifolds.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-26-2010, 05:06 PM   #13
Sean@Phastek
We didn't get a chance to do any before & after dyno testing, mainly because this car already has a cold air intake and exhaust. We might put it on the dyno with this complete setup and see how much power we get to the wheels; with and without a tune.
As far as installation, we had to disconnect the steering shaft as well. Easy enough though, as it just slides up and out of the way. Sound quality improved a bit as well...
Old 04-27-2010, 01:02 AM   #14
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
We didn't get a chance to do any before & after dyno testing, Sean@Phastek
Then whats the point!!!!
9/26/09 Took delivery!
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
High Flow Cats with Shorty Headers? Aaron1121 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 07-06-2010 02:56 AM
BBK Shorty Headers V8 LS3/L99 - Chrome, Ceramic Coated, or Stainless Steel Sean@Phastek V8 Bolt-Ons & Tunes 10 06-09-2010 01:30 PM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
