Old 04-20-2010, 12:38 AM   #1
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Clean Sweep Location
Where is everyone putting (physical location) the clean sweep box and the signal summing box? I have a 1LT Synergy so no amp in back, where exactly do you wire in the Clean Sweep and signal summing module? Does it require a lot of work in the dash? Do you have to run seperate wires from the amp to each speaker then?
I would love if someone with a Clean Sweep could give me some details and pics of how it is installed. Thanks.
terry_b is offline   Reply With Quote
Old 04-26-2010, 11:10 AM   #2
terry_b
terry_b's Avatar
Bump...
I'm supposed to have a Cleansweep installed next monday... could save $400 if someone has any info to help me do it myself. I'm looking for wiring info, locations, etc. Thanks.
Old 04-26-2010, 12:06 PM   #3
Racer-X
Rhymin and Stealin
Drives: The Search is on ABM V6.....
Send a message via MSN to Racer-X
do you have the BA system or non BA? if you have the BA system you can install the CLeansweep in the Factory amp Location in the lt rear behind the tail light.
Racer-X is offline   Reply With Quote
Old 04-26-2010, 12:16 PM   #4
SRFnSNO
SRFnSNO's Avatar
Drives: Blown & Flamed
I have a 1bit Processor simular to Clean sweep.
it is mounter under the rear deck between the to rear speakers.
have a additional multi-Channel amp and sub added to BA System
SRFnSNO is offline   Reply With Quote
Old 04-26-2010, 08:19 PM   #5
terry_b
terry_b's Avatar
I have non-BA system. Where could I find a wiring diagram for the wire runs down each door - i.e. where can I splice in the Cleansweep easily without tearing apart the car too much?
Old 04-27-2010, 08:36 AM   #6
Droid6
Droid6's Avatar
Drives: 2010 Camaro LS
If the bass is being attenuated as the volume is being raised like suggested here on this forum what would be the point of using the cleansweep? The signal is still going to be jacked.
Droid6 is offline   Reply With Quote
clean sweep
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 124 02-05-2024 10:55 PM
JL Clean Sweep nalinc23 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 04-16-2010 04:06 PM
Stoner Invisible Glass Reach & Clean Tool Replacement Bonnets At ProperAutoCare.com Angelo@Autopia Wash/Wax/Detailing and Cosmetic Maintenance Parts 2 02-16-2010 10:35 AM
JL Audio Clean Sweep Lightson357 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 01-19-2010 03:14 PM
Mr Clean Auto Dry & waterblade? Matt'sSS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 3 08-17-2009 01:19 PM
