![]() Drives: 2010 Camaro SS Join Date: Jan 2009
16" Bogart drag wheels
Jannetty Racing has just installed the first set of 16" Bogart drag wheels on a 2010 Camaro SS. These wheels are very light and extremely well built.
The fronts weigh 16lbs and the rears weigh 16.5lbs. That's a 16lbs weight saving PER wheel over stock. These wheels will NOT fit over the Brembos, you must change over to v-6 brakes. The v-6 brakes are a direct bolt on fit, no mods needed. These wheels will be available thru Jannetty Racing.
9.82 @ 139 mph
Vortech YSI cog drive supercharger w/ JRE Upgrade Pack Untouched LS3 Long block sans the Cam and valvetrain 14.5 psi boost JRE Rough Idle Blower Cam ADM Fuel system & Injector Dynamics ID-1000s ARH 2 inch Headers, off road pipes TCI TH400 Trans & 5000rpm stall w/trans brake DSS 9 inch conversion with 3.93 Bogart Wheels and Hoosier tires Jannetty Racing tuned 800 rwhp |
| What song are you listening to right now | Muscle Master | Off-topic Discussions | 6760 | 11-08-2025 02:54 AM |
| Camaro Set up with Drag Package | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 11 | 05-03-2010 11:33 PM |
| 20" MS Wheels (only) For Sale: You Pick the Combo | chrisgalles | Wheels / Tires | 3 | 02-18-2010 12:19 AM |
| Wheels! Your Camaro needs forged wheels. | Nine Ball | Wheels / Tires | 42 | 12-21-2009 11:51 AM |
