2G1FT1EW0A9118618
Drives: 2010 Camaro 2SS Black/IOM M6 Join Date: Dec 2008
Both rear shocks need to be replaced
I took my car to the dealership today because my car has been riding a bit rough lately. I found out that both rear shocks are leaking and need to be replaced. It is covered under the warranty so no big deal. I was wondering if what caused this was putting it up on jack stands for the winter? I do not take it on rough roads and the jack stands make the most sense. Any thoughts or opinions would be appreciated. Thanks
1100, Preliminary order accepted 12/5
2000, Order accepted by GM 05/05 3000, Order accepted by production control 05/05 3400, Order broadcast 6/4 3800, Order produced 6/15 4000, Available to ship 6/16 4104, Bailment Invoice 4200, Shipped 6/19 6000, Delivered to the customer 6/25 2SS/RS BLK M6 GFX IOM interior |
![]() Drives: 2010 Chevy Camaro 2LT Summit White Join Date: Dec 2009
DO you mean you keep the car on jackstands while its being stored? Like removing all load form the wheels/shocks.
Im not sure if thats necessary. But If you did do it Im not sure how that could be harmful to the shocks. Probably got a bad pair of course Im not expert. |
Sask-man from Sask
Drives: 2010 1SSRS M6 Black of course! Join Date: Aug 2009
Most likely just some bad shocks.
Average car 20,000 parts so if your car comes out 99.9% perfect, there are still 20 parts that aren't! Ya it's a drag but a simple quick and easy fix. |
God Bless Dawson
Drives: Synergy for my Daughter Join Date: Feb 2010
Placing you vehicle on jackstands does no damage to your suspension. It is no different than the car sitting on the wheels. Except your tires won't develope flat spots.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Hmmm.....I'm about to lower my car with drop springs. I wonder if in a couple months I had the same thing, took it to the dealer, and then they say "aftermarket springs caused the shocks to go bad.....no warranty work"?
Anyone think that might be the case?
Build Journal ![]() |
#6 | |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
#7 |
Unless your dealer is super cool, they will most likely not cover the shocks. In that case they would have a pretty strong case in blaming the faulty shocks on your drop springs.
#8 |
![]() ![]() ![]() Drives: 2010 Camaro Join Date: Mar 2010
OP sounds like you just got a couple bad parts, doesn't sound like you did anything wrong.
It's up to the dealership, I'd talk to them and see what they have to say before doing it.
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet... |
#9 |
![]() ![]() ![]() Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
But both shocks, if you were to get a random bad part would there be two in a row? Maybe they were training someone that day in the shock factory? Or maybe the jack stands for the winter?
The Yellow Camaro Club
![]() http://www.camaro5.com/forums/group.php?groupid=128 Northern Massachusetts & Southern New Hampshire Camaro Club ![]() http://www.camaro5.com/forums/group.php?groupid=127 The mother of all supercharger questions thread ![]() http://www.camaro5.com/forums/showthread.php?t=77958 My 2010 Camaro Review ![]() http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442 2010 Transformer Edition Camaro L99 Auto ![]() ![]() ![]() |
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
i have seen several bad shocks/struts, leaking
#11 |
Is there a TSB on it? or a vin# break point ?
#12 | |
it happens all the time with brake master cylinders,, someone blows a brake line, pedal goes all the way to the floor, you fix the brake line or whatever leaked,, then you bleed the brakes and find out the master cylinder seals are bad,, same reason as above.
New from RPI! 2010 Camaro Pre-Painted Body Color Rear Spoiler! $399.00, painted! | RPI Designs | Exterior Parts & Accessories | 10 | 03-25-2010 02:42 PM |
2010 Camaro SS Blue in Syracuse NY $32690 | Mitsubishi in Syracuse | Camaro Price | Ordering | Tracking | Dealers Discussions | 0 | 12-31-2009 02:44 PM |
2010 Blue SS for $32990 and we pay for your plane ticket! | Mitsubishi in Syracuse | Dealer Camaros for Sale | 0 | 12-21-2009 12:42 PM |
Steering response.... | CGM2SSRS | Wheels and Tires Talk Sponsored by The Tire Rack | 130 | 10-21-2009 05:04 PM |
Pfadt Carbon Rear Trailing Arms and Rear Tie Rods | PfadtRacing | Suspension / Brakes / Chassis | 20 | 10-18-2009 09:46 AM |
