![]() Drives: 2010 2LT RJT Auto - Camaro/2004 Sub Join Date: May 2009
Cooling System problem?
This evening a friend said he has been considering buying a Camaro. His son told him today to be careful..................because he just heard there is a cooling system problem.............overheating on long trips.
Is anyone here aware of such an issue? |
Supercharged
Think they're referring to an old TSB on a certain range (somewhere in the 15000-30000ish) VIN# of 2010s. You take it into the dealer to have some software updates done.
2SS/RS IBM A6, White Rallies
Ordered: 4/30/09 Delivered: 8/18/09 Appearance Mods: Heritage Grille, ZL1 Replica Wheels Performance Mods: Flowmaster ARH Cat-Back Exhaust, ADM CAI, ADM L99-LS3 Conversion, ADM LSA Supercharger Kit, Lingenfelter GT9 Cam, Stainless Power Headers, Detroit Speed Sway Bars, ZL1 Fuel Pump 581 rwhp/535 lb/ft tq |
![]() Drives: '19 Camaro 2SS, '12 GMC Yukon Join Date: Oct 2009
Two weeks ago I drove my 1LT/RS from SW PA to Fuquay-Varina, NC in one day (9 hours). It was 93 degrees in NC and the last part of the trip was in heavy traffic. I experienced NO overheating.
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
Lots of people made LONG trips to Camero Fest.......5 people from our club.....none of them had any issues.
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
I was gonna say, we just had several hundred Camaros make the trek to Valdosta from all over the country and I hadn't heard of anyone having cooling issues...
#6 |
![]() ![]() Drives: C63 P31 Join Date: Feb 2010
I just had a Vortech V-3 Si supercharger installed on my 1SS L99 and my car is having a very bad heat problem. If I make one little WOT run, my coolant temp will reach beyond 220 degrees F. That means my engine oil temp is getting near 250 degrees F.
When I'm driving long distances my car does not have any problem with heat. But as soon as I come to a stop my car's coolant temp goes through the roof. I'm constantly worrying that my engine will get damaged, so I stop and turn my car off. I wish I knew what to do. Anyways, I'm having heating problems but I'm sure the supercharger is the cause. Still, it's questionable because plenty of others have blowers and they don't have any heat issues. |
#7 | |
![]() Drives: 2010 2SS Join Date: Apr 2010
#8 |
![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
Thermostat stuck closed?
#9 |
Echale Gas [COTW 3/10/14]
Drives: 2010 Camaro SS/RS Supercharged Join Date: Aug 2010
Please advise on this. I should have seen this forum before I bought the car :(
Very bad to know after just buying the car :( BTW I bought SonnyakaPig car (he didnt sell it to me it was a dealer after he traded it in), I was not having these problems at all the first 2-3 days but after driving a bit further I have the same issues. This is the price I have to pay for buying a used car :/
Kenne Bell 502 rwhp/ 471 rwtq at 9psi (daily driver...for now) Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers |
#10 | |
![]() Drives: 2010 2LT / RS - 2013 ZL1 Join Date: Aug 2010
Your ride is still covered with warranty isn't it? |
#11 |
Well it would be if it didn't have a supercharger in it. What I'm saying is that buying a used car can be a gamble, and currently im losing.
Hopefully this fix will not be too costly.
#12 | |
For example, I thought engine coolant temps of 220* F was dangerous. It's not -- not even close. When I removed the Vortech supercharger (installed and removed by Vortech so it was in good hands) the car stopped running as hot. And when I installed the Kenne Bell which comes with a lower temp T-stat, the engine coolant temp actually ran cooler than stock. I'm very sorry that your car is overheating. I made numerous 4 hour trips through 105+ degree heat with air conditioning blasting and never overheated. I was paranoid before and that's why I would shut the car off when the Engine Coolant Temp would get over 220* F. The strange thing with your experience is that your engine coolant guage with the dial is actually at it's max (hottest) and I don't remember ever seeing the deal go much past the middle mark. And I checked it a lot. You should take it to the dealer and see what they say. If the car needs to be tuned, that's not that much. |
#13 |
No issues here with overheating. Lots of extended trips this summer.
#14 | |
In any case good luck and keep us updated! |
| PERRIN Performance Water/Methanol Injection Kit | PERRIN_JOHN | Forced Induction | 4 | 03-17-2010 10:57 PM |
| GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 02:56 PM |
| Nitrous Outlet 2010 Camaro Nitrous System and Accessories! | Nitro Dave | Forced Induction | 9 | 11-27-2009 12:49 AM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 10:03 PM |
