Old 04-23-2010, 02:56 PM   #1
JohnForeman
Drives: 2010 2SSRS
Any Threads on removing the Stock Head unit?
Has anyone done a good howto on removing the stock head unit. I did some searching but didn't find anything.
thanks
2010 2SSRSA6 - GFX
35% Window Tint
93 Octane Diablo Predator Tune
JohnForeman is offline   Reply With Quote
Old 04-23-2010, 03:47 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
With a dash trim removal tool, pry up on the shifter bezel releasing all clips
Shift shifter to “M” (or neutral if M6) and remove the shifter bezel
Remove (2) 7mm screws from the bottom of the radio bezel
Remove 2 remaining screws on radio
Pull radio out
Old 04-26-2011, 08:42 PM   #3
C586
Drives: 2011 Camaro LS
Dont mean to bump a really old thread but is it really that easy??
C586 is offline   Reply With Quote
Old 04-26-2011, 08:53 PM   #4
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
if you need pictures check out the diy on the hud in the diy section
camaro4mybday is offline   Reply With Quote
Old 04-26-2011, 11:26 PM   #5
Kunihiro1
Kunihiro1's Avatar
Drives: 2010 CGM 2SS/RS
When I had my Metra kit installed, I took a few pictures. Here is one with the head unit removed. With "slick rick's" directions, you will be able to see what screws and locations he is referring to
The gauge panel will have to be removed in order to access the two screws on the bottom.
You can see the screw holes where "slick rick" has made reference to. You can also see the areas where you are going to have to focus on with your pry tool.
Hope this helps.
Allen
'69 SS Camaro
2SS/RS, CGM, Magnaflow Exhaust, Pfadt Suspension, Airaid intake (Sold)
71 RS Camaro (Sold)
Z Car (Sorry, Nissan 350Z)
Kunihiro1 is offline   Reply With Quote
Old 04-26-2011, 11:37 PM   #6
C586
Does the console really need to be pulled apart that far?? Was hoping it was just where the 4 pack gauges would be?? I have to pull it out to hook up my pac connector for RCAs.
Old 04-27-2011, 01:20 AM   #7
black.
Drives: IBM 2SS
Use this
http://youtu.be/Cktl99S4O_U
black. is offline   Reply With Quote
Old 04-27-2011, 02:27 PM   #8
Kunihiro1
Kunihiro1's Avatar
Actually, my installer, pulled out the console, so he could get to all the wiring. But I don't believe you have to actually pull it back that far. Not 100% sure though...... Primarily, that panel that houses the gauges needs to be removed.
'69 SS Camaro
71 RS Camaro (Sold)
Old 04-27-2011, 02:50 PM   #9
camaro4mybday
"Camaro Joe"
you need to put the top with the 4pac gauges off, this way you can get to the screws, it should take about 1 or 2 mins to get off completly
Are the Boston Acoustics & base head unit the same? hdhomer Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 34 01-19-2012 01:54 AM
Tips for First Timer MrCool 4th Generation Camaros 123 10-31-2009 08:37 PM
Be careful cleaning Head Unit Screen tjd24 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 05-29-2009 07:05 PM
Bad news for anyone thinking of installing an aftermarket head unit fastball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 26 05-26-2009 11:18 PM
Song Information Displayed on Head Unit ravensjeff Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 32 03-16-2009 05:28 PM
