04-23-2010, 02:09 PM | #1 |
Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
I need a Favor ASAP...
Can some of you folks with an LS3...or L99 for that matter please do me a favor???
I would like to know if you could go ahead and start the car and let it idle, then please let me know the psi reading on the 4guage pack at idle, as well as at 2k RPM. I would really appreciate if you a few of you could do this for me, I want to ensure I am getting the proper oil pressures in my car since the big engine swap. Please post what engine you have and what the psi is... Thanks for the help!! |
04-23-2010, 02:18 PM | #2 |
Drives: One of the rare ABM camaros Join Date: Apr 2009
LS3 at idle was a bit over 30 lbs. I will have to pay attention at 2k rpm and let you know.
Dean
2000 5/23 3000 5/27 3400 6/20 TPW of 6/29 3800 7/3 4D00 7/8 interned at QC 4B00 7/16 Released from QC 4200 7/20 8/5 We picked up the car |
04-23-2010, 02:24 PM | #3 |
OK... Thanks... I still need some more input here. I really need to see numbers from more of you folks.
04-23-2010, 02:52 PM | #4 |
Anybody else that can run out to their car and check this for me real quick?
04-23-2010, 02:57 PM | #5 |
Drives: 2010 Camaro 2SS/RS ABM Join Date: Jun 2009
idle a bit past 30 and at 2k it was a bit past the next hash before 70 not sure what numebr that would be
2SS/RS/M6 | ABM | White Stripes | Black Int
Mods: American Racing Headers & Exhaust, Airaid Intake, Pfadt Front/Rear Sway Bars, Stealth Bulbs, AAC LED bowtie, AAC Concept LED Side-markers ABM/Tinted, 20% Tints, Chuck COW Tune, MGW shifter (blue with white racing stripes). Coming Soon: 4:10 Gears? |
04-23-2010, 03:10 PM | #6 |
Tampa Gulf Coast Family
Drives: 1977 Z28, 2SSRS 2010 M6 Join Date: Sep 2009
Like the other post 30 psi at idle and the next hash mark at 2000 rpms. LS3 here.
04-23-2010, 03:16 PM | #7 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
~30 at idle
at hash between 30 and 70 at 2k
04-23-2010, 03:38 PM | #8 |
OK thanks everybody... It seems as though I am reading much lower than that...
Here are my thoughts. If it was really that low, I would be getting a check oil light at 20psi or lower). Mine is reading around 17 at idle on the 4-pack gauge. I am guessing that it is inherently unaccurate anyway. This does concern me, but I think I need to get it plugged into HP tuners or something similar and have a real readout given ASAP. Thanks for the help, and I would appreciate any thoughts you folks would have. |
04-24-2010, 12:47 PM | #9 |
480 HP 2010 2SS
I have an issue with my oil pressure reading. I have taken it to to the dealer and they called the regional service tech and said it was within spec and I shouldn't worry unless I saw an oil light, but I call . When the engine oil gets to operating temp ~ 200 deg. F my oil pressure at idle is only about 8 psi and at 2K rpms it is ~ 27 psi and when cold it is only a tic higher at both rpm levels. When I first got my car it was more in-line with what you other guys have been saying yours is at but as of late there was a big step change. I am not satisfied with the answer the service tech gave and I fear there is irreparable damage being done every time I drive it. And yes I have changed my oil with Mobile 1 5w30 synthetic twice already with 7k miles on the odometer. I think my best solution is to tell them I saw an oil light come on temporarily and they need to fix it, otherwise they aren't going to touch it.
Without data you are just another person with an opinion.
1100 :10/15/08 3000:3/2609 3300:4/18/09 3400 (broadcast)April 25, 2009 3800 (produced):May 4, 2009 #7470 4200 (Shipped): June 1, 2009 5000 (At Dealer) June 9,2009 374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg. |
04-24-2010, 01:40 PM | #10 | |
Drives: 2010 IBM 2SS/RS Join Date: Feb 2010
PIP4158C: Low Oil Pressure Due To Seized Oil Pressure Relief Valve - (Dec 29, 2009) Subject: Low Oil Pump Pressure due to Seized Oil Pressure Relief Valve Models: 2008-2009 Buick Lacrosse, Allure (Canada Only) 2007-2010 Cadillac CTS-V, Escalade 2007-2010 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe 2007-2008 Chevrolet Monte Carlo SS 2007-2009 Chevrolet Impala SS, Trail Blazer 2009-2010 Chevrolet Colorado 2010 Chevrolet Camaro 2007-2010 GMC Envoy, Sierra, Yukon 2009-2010 GMC Canyon 2008-2010 Hummer H2 2008-2010 H3 Alpha 2008 Pontiac Grand Prix GXP 2008-2010 Pontiac G8 GT 2007-2009 Saab 97x with the Following Aluminum V8 Engine RPOs: L76, L77, L92, L94, L99, L9H, LC9, LH6, LH8, LH9, LS2, LS3, LS4, LS7, LS9, LSA, LZ1 The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Some customers may complain of low oil pressure, no oil pressure, and/or engine noise, which may be the result of a sticking oil pump pressure relief valve. In some instances, this may occur intermittently if the valve frees up when the engine cools down. Recommendation/Instructions: If SI diagnosis isolates low mechanical oil pressure at the oil filter housing and oil pressure sensor, replace the oil pump, flush the oil cooler lines (if equipped), clean the inside of the oil pan, change the oil and filter, and re-evaluate the concern. Notice: If an engine noise is noticed after replacing the oil pump, follow the SI diagnosis and repair the engine as necessary. Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. Nothing says the light must come on for them to diagnose the issue...
2010 IBM 2SS/RS Camaro (M6) Previous rides: 2003 Twin Turbo Mustang Cobra(900 RWHP) 2004 KB S/C Mustang Cobra(700 RWHP) 2003 Mustang GT,Heads,Cam, N20 ect.. |
04-24-2010, 01:59 PM | #11 |
Bring It
Just did a cold start on mine...
At idle after cold start the guage rests between the 30 line and the next unlabeled line. At 2K after cold start the guage rests a bit above that unlabeled line. |
04-24-2010, 03:04 PM | #12 | |
I am going to install a new High Pressure pump and then double check everything again... |
04-24-2010, 03:32 PM | #13 |
480 HP 2010 2SS
Yep, I knew about that posting. I actually printed it out and carried it to the dealership, still nothing. They did diagnose it and said "it was within spec."
04-24-2010, 04:12 PM | #14 | |
Where are you located?
