Old 04-24-2010, 12:06 AM   #1
strobi
MJ STROH
Drives: 2010 Camaro 2LTRS
JBA or Doug Thorley shorty headers ?
Have installed Magnaflow catback exhaust, now thinking of adding headers....will they void warranty? I like the JBA shorty headers or the Doug Thorley shortys One better than the other? what about install..which seems to have few problems? Would appreciate your coments and concerns about their addition Thanks mjstroh
strobi is offline   Reply With Quote
Old 04-24-2010, 12:16 AM   #2
Ivan @ Southwest Speed
Check out my V8 install...same thing minus a couple bolts.
http://www.camaro5.com/forums/showth...install+review
Then PM me when you need to buy em.
-Ivan
Old 04-24-2010, 12:22 AM   #3
iBK3000
Drives: '04 Range Rover, Camaro 2SS 6MT
Neither will help. But they will look cool!
CGM 2SS/RS 6SM . No muff.
iBK3000 is offline   Reply With Quote
Old 04-24-2010, 02:59 AM   #4
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
Incorrect. Look at the recent post by John VS:
http://www.camaro5.com/forums/showthread.php?t=79379
wbt is offline   Reply With Quote
Old 04-24-2010, 12:14 PM   #5
mrray13
Drives: 2010 1LT RS Rally Yellow
Indeed, shorties can help, just not as much as LTs. At least on the 3.6 we've seen gains!
mrray13 is offline   Reply With Quote
Old 04-24-2010, 01:35 PM   #6
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
To bad I keep getting engine codes with my jba's
chevy 3 is offline   Reply With Quote
Old 05-25-2010, 04:53 PM   #7
2010 4 DW
Drives: White 2010 RS/SS
Bad install is what is causing the codes. You have an exhaust leak for sure that is letting fresh air hit the 02 sensor and there is the light.
My buddy had the same problem and when the shop checked out the install we found out it was not sealing all the way. Make sure you reset your PCM.
DW
2010 4 DW is offline   Reply With Quote
Old 05-26-2010, 05:04 PM   #8
Mikk2K
Mikk2K's Avatar
Drives: '10 Camaro LTRS, '12 Pro4x Frontier
My JBA's keep throwing a CEL as well. I've had them checked and rechecked and been unable to find any leaks. I would go for Doug Thorley if I were you.
Mikk2K is offline   Reply With Quote
Old 05-26-2010, 05:32 PM   #9
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
I still haven't seen a CEL with my dealer installed JBA shorties after 7k plus miles.
Just may be lucky but from all the reports I would go with the DT's. They look to be an all weld install and would be less prone to leaks around the stacker clamp that the JBA's use.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 05-26-2010, 05:39 PM   #10
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
I have already been pm'ing with "bad karma" (ivan) for the last few days to get on the list for the DT shorties
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 05-26-2010, 05:41 PM   #11
Abygale
Abygale's Avatar
Drives: .
No CELs yet on my DT headers. Love them....just need to get the car on the dyno now.
Abygale is offline   Reply With Quote
Old 05-26-2010, 06:01 PM   #12
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Forget the dyno, you look to be ready for the 1/4 mile.
We need more folks on the V6 fast list. You would certainly have a weight advantage over the fellows there.
I need to lose a pound or 30.
Old 05-26-2010, 08:22 PM   #13
Abygale
Abygale's Avatar
Drives: .
Thanks 67, I may have to give the 1/4 mile a try. I will be up at Heartland Raceway on June 16 for a track day (this month's got rained out), hopefully they will have the drag strip open as well.
I really want to get a smaller and lighter wheel/tire setup but I don't like how much gap that creates in the wheel well- not a lot of affordable options out there right now anyway.
Old 05-27-2010, 01:09 AM   #14
Thank you sir!!
Prolly another 3-4 weeks out for those stil considering them.
-Ivan
Doug Thorley Shorty Headers :: +20rwhp, +35rwtq! Sean@Phastek V8 Bolt-Ons & Tunes 67 01-20-2014 09:25 PM
Doug Thorley Shorty Headers for 2010 Camaro Installed -WOW! Rallyman6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 03-13-2011 01:36 PM
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 04:51 PM
Doug Thorley headers and axle-back ROCKS! SPANKT U Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 01-07-2010 11:36 AM
Doug Thorley Shorty Headers and SLP Loudmouth II installed! teapot Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 11-17-2009 10:34 AM
