Old 04-24-2010, 07:35 PM   #1
spacecowby
spacecowby's Avatar
Drives: 2010 black 2SS/RS
Fuse pull question?
I have read alot about people puling fuses for various reasons. Mainly to remap something. Question is what is this used for? and what fuse would you pull and for how long?
Thanks
spacecowby is offline   Reply With Quote
Old 04-24-2010, 07:39 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
http://www.camaro5.com/forums/showthread.php?t=38964
It's all there.
Old 04-24-2010, 07:44 PM   #3
Gforce8
WFO all the way
Gforce8's Avatar
Drives: Hyper Blue 2SS, Kalahari, 6 speed
Do a search for "fuse pull".You'l find the explanations.
The computer has a "learning ability that constantly adjusts for your driving style and measures the fuel you use via a knock sensor. It adjusts LTFT & STFT Lon term/short term fuel trim.
If you use regular instead of premium it will detect 'knock' under load and adjust the timimg and fuel to prevent it. This costs you probably a coule of horsepower.
It was argued by a few people with engine analyzers that for some reason ome camaros would not relearn if tey were on premium.
The fuse pull makes the ECM (computer ) forget and start from scratch.
hope this helps.
So to regain max HP
2016 2SS -no mods
Gforce8 is offline   Reply With Quote
Old 04-24-2010, 10:47 PM   #4
spacecowby
spacecowby's Avatar
thanks
I've a question for our police officers.. ahart04 Off-topic Discussions 309 09-18-2011 04:48 PM
check engine light question shroomjohn Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 08-02-2010 01:25 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
LS3: fuse pull or battery disconnect?? g-townmach Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 12-28-2009 08:31 PM
A way to tell if you need the fuse pull looking at timing? defragme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 12-07-2009 08:48 PM
