Old 04-25-2010, 11:23 PM   #1
Tibbs-86
Drives: '08 Silverado 1500 WT
Send a message via AIM to Tibbs-86 Send a message via MSN to Tibbs-86
i know its a diesel but still
so i am driving to taco bell on lunch the other day in my 97 Chevy K2500 6.5 Turbo Diesel, and i loose everything, Power steering, power brakes, Tach is reading 0 RPM, battery light is on.
my dumb self says "oh, you are not stalling on me. not here in the suicide lane"
so i rev it just a little. and i hear multiple BANGS. (i read that it is possible to shear the crank on these motors) so i think to myself, "i just destroyed my crank"
call work tell them, i'm going to be late. call a buddy (not going to throw Spike under the bus) but the first buddy doesn't answer, call another buddy. in the end i get towed a little over 3 miles from taco bell to my buddy's place, get the truck in the car port. start pulling everything apart to see if there is any other damage, and HERE IS MY HARMONIC BALANCER sitting in the little gap between my harmonic balancer and my axle.
call work again. tell them the situation they say, "take the rest of the day off, fix the truck"
so i am looking at the crank stub and there is this horrendous gouge, so if any of you have seen my camaro you can probably guess what happened there. new harmonic balancer. new belt, new crank key chuck, J B WELD. new fan clutch, and still looking for a new fan.
THIS HAS GOT TO BE THE MOST EXPENSIVE CUT BACK FROM WORK I HAVE EVERY HAD, so far approx. $400 just to get half a day at work.
haven't got the truck up and running yet. still have about 2 hrs left on the cure check for the j b weld.
well at least i have another vehicle to drive, my '08 Silverado. its a good thing this didn't happen while my '08 was at the fest and i wasn't.
i am still in awe of, how does the harmonic balancer just FALL OFF. really who does this happen to.
2008 Silverado 1500 WT 4.3L v6
1986 Camaro LS1 Edlebrock 650cfm CARB, 700R4 3200 stall....more to come
1997 K2500 6.5 turbo diesel, with Silverado package
Tibbs-86 is offline   Reply With Quote
Old 04-25-2010, 11:32 PM   #2
ron10
Drives: 2010 2SS IOM L99
man that sucks.hope it doesn't cost much more to get you up and running.
Old 04-25-2010, 11:37 PM   #3
Tibbs-86
me either i was planning go visit family this summer, possibly pulling my 86 camaro
Old 04-26-2010, 08:47 PM   #4
Big Brunsy
Drives: 2010 supercharged LS3
the vehicle guru at work said there is a preventative maintenance check for that. you're supposed to check ur harmonic balancer for tightness every so many miles on them, forget how many tho
Big Brunsy is offline   Reply With Quote
Old 04-27-2010, 09:53 AM   #5
Jason L
Drives: 2004 Pontiac GTO
A lot of the older GM Crank balancer's sucked, we have had vettes that they are coming apart after 30-40k. Or a cool one is when you are on the dyno and it spins off, makes some interesting footwork to get away from. Have seen a guy going down the track and the Balancer separated and took out all kinds of things under the hood. Sucks man I am sorry.
Jason L is offline   Reply With Quote
Old 04-27-2010, 12:21 PM   #6
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Ummm, JB weld, seriously? What part are you using it on? I have never seen it hold on anything that has a load on it or is spinning. Just sayin', I would be very leery of it....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 04-27-2010, 07:42 PM   #7
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
basically the rubber went bad and it broke free, I have seen it many times. We had customer lose one vertical through everything including the hood, it was nasty. What part are you JB welding?
Superman09 is offline   Reply With Quote
Old 05-02-2010, 10:11 PM   #8
Tibbs-86
Well the truck is back up and running like a champ. The JB WELD was used to fill a small gouge on the crank stub. Its not a permenant repair. But it should be ok, since the gouge was mostly cosmetics were it was and the size,
But the main story is the truck is alive again
Camaro Diesel Muscle Car? KILLER74Z28 5th Gen Camaro SS LS LT General Discussions 142 03-14-2014 07:38 PM
New 4.5 L Duramax Diesel V8 for light duty pickups Scotsman General Automotive + Other Cars Discussion 8 12-01-2008 06:21 PM
Large passenger cars going diesel in Oz Scotsman General Automotive + Other Cars Discussion 10 04-24-2008 06:57 AM
Big Oil seems slick as U.S. turns to diesel cars Scotsman General Automotive + Other Cars Discussion 2 04-16-2008 04:23 PM
Big 3 to make diesel an option to domestic customers Scotsman General Automotive + Other Cars Discussion 8 01-02-2008 12:10 AM
