2SS CGM with IOT
Opinions on Redline Oil
I know it's a 100% synthetic ester based oil. But does anyone run this in your Camaro? Also thinking about getting Transmission and Rear Diff changed with appropriate Redline products as well.
Anybody with some opinions? |
My father-in-law and I who both have gen5's just ordered some. He has a friend that has been running it in his Corvette for years and swears by it.
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
I have it in my rear diff and like it quite abit. I also have some that I need to put in the trans just have gotten around to doing it. Since I change the engine oil more often I use mobil one for that.
![]() Drives: 2SS, 48 Plymouth, 77 Coup Deville Join Date: Nov 2008
Compare specs and you will use Amsoil. It is the best.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
If the top 3 synthetics were Blondes, Brunettes, and Redheads, and you had to pick one. You could not make a bad choice. They are all great, some folks just have a particular flavor programmed into their brain that they think is the best.
And anyone that says one is better than the others is flat wrong. If you took 3 Camaros. Run 150,000 miles on them all. One using Redline, one Royal Purple, one Amsoil. In the end, I'd wager there would be next to no difference. Show me a Camaro with Amsoil, and prove that it is doing something better than a Camaro with any other brand of synthetic that meets the GM spec. That's like saying, wow this car really runs great using Redline oil. How so? I've never been able to feel a difference in a cars performance based on brand used. I'd bet if I put Walmart Superlube 5w30 synthetic in a blind taste test up against any of the top synthetics, nobody could tell the difference. Put 4 cars out on a track, with expert drivers, go tear it up and come back and tell us which one had the "inferior" oil. No possible way anyone could tell a difference. Those that proclaim superiority are most often generating an income from that claim. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
as long as it meets GM specs,you won't have a problem.
#7 | |
Semper Fi Camaro
Drives: 2010 1SS/RS Aqua Blue LS3 Gauge PKG Join Date: Jan 2010
#8 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I am running it in my Maro. We use it in our 6 second Pro Street car, got to be good enough.
#9 |
![]() Drives: 1969 Chevelle, 2010 1LT Join Date: Jun 2009
I put it in my rear diff and M6 tranny. I have the V6. I haven't put it in the engine yet. To be quite honest, I can't tell any difference between the Redline and factory fluids. I was hoping for better shifting in the cold, but it doesn't shift any better. I do believe it's a quality product though or I would not have used it.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation 2000: 8/15/09 - Accepted by GM. 2500: 8/18/09 - Preferenced. 3000: 8/18/09 - Accepted by Production Control. 3100: 9/9/09 - Available to Sequence. 3300: 9/9/09 - Scheduled for Production. 3400: 9/19/09 - Broadcast. 3800: 9/29/09 - Produced. ![]() 4000: 9/29/09 - Available to Ship. 4150: 9/29/09 - Original Invoice. 4200: 10/6/09 - Shipped. 5000: 10/13/09 - Delivered to Dealer. 6000: 10/13/09 - Delivered to Customer. |
#10 | |
![]() Drives: none Join Date: May 2010
the reality is when you compare data you will see the difference, you wont see it today or tomorow but years down the road,,, when you start saying dam why are my cylinders so scored, dam why are my crank,rods,and main bearing wearing out more than the people using good synthetics.
then you will realize,, but then would be a little late. for example its so funny and bizare on how royal purple claims to have a top notch synthetic media that cost 12 buck + and that filters 20 microns,,, dam even a 5 dollar synthetic media WIX filter is capable of better than that AMSOIL's EA filters are rated at 10 microns ,,, a BIG significant difference. Quote:
#11 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
You could tell by the temp gauge, less friction=less heat=more power
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
#12 |
#13 |
#14 |
![]() Drives: Red LT1 & Silver LS3 Join Date: Feb 2010
| My V6 oil change experience | convert | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 38 | 04-08-2014 05:15 PM |
| Oil Changes | Dave McFly | Off-topic Discussions | 6 | 05-18-2010 05:50 PM |
| GM's OLM & synthetic oils. | duder4thgen | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 03-24-2010 12:37 PM |
