Old 04-26-2010, 09:25 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
What are some good cheap wheels for some drag radials
I'm thinking about gettting some drag radials to use when I take the car to the drag strip. What are some good reasonably priced wheels that I can use to put them on? I heard that Corvette Z06 wheels will fit.
What is the smallest size wheel that will clear the Brembo brakes on the SS? I thought I saw where someone said some 17" would fit but that seems small for that size of brake.
I'm thinking about getting some Nitto 555R tires. Anyone used these or have any other recommendations?
Build Journal
Old 04-26-2010, 06:01 PM   #2
thesubfloor
Drives: 2010 Camaro SS
I ran some pretty decent (and consistent) times last week with 18" C5 Z06 rims and BFG drag radials:
http://forums.corvetteforum.com/c6-t...i-m-a-fan.html
I had to secure both of the e-brake cables away from the rims but other than that they worked well.
thesubfloor is offline   Reply With Quote
Old 10-18-2010, 01:19 PM   #3
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
Did you use front or rear Vette wheels?
ParisTNDude is offline   Reply With Quote
Old 10-18-2010, 01:23 PM   #4
thesubfloor
Rears, as the 17" fronts won't clear the Brembo brakes.
Old 10-18-2010, 02:10 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Here at BMR we use the 18" C5 Z06 rims also with a Mickey Thompson drag radial (305/45/18) and we generally cut low to mid 1.5's 60fts. They clear the stock Brenbo brakes with a small spacer and they are pretty easy to come by.
Old 10-18-2010, 02:12 PM   #6
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Beat me to it... can get these wheels for 80 bucks apiece...
Old 10-18-2010, 03:08 PM   #7
caverman
caverman's Avatar
Nice 60' times. Is that on pretty much stock setup of a fairly modified car?
Where can I get some for $80 or so? That's cheap enough for me to do.
Aren't a set of MT's about $160 a piece?
Build Journal
Old 10-18-2010, 03:11 PM   #8
nyny69
Drives: 2010 IOM SS
I'd love to know also
nyny69 is offline   Reply With Quote
Old 10-18-2010, 03:15 PM   #9
caverman
caverman's Avatar
30X12.00R18LT
That's all I can find so far. Looks like about $300 ea....OUCH...not cheap for someone that only goes to the strip a 3-4 times a year.
Can't find the 305x45x18 ones.
EDIT: Finally found them. They are ET Street Radial II. Still about $300 ea.
Build Journal
Old 10-19-2010, 07:28 PM   #10
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I was at a Dyno Day last weekend and we were discussing a set that was on an SS in the shop... They said cost was 80 and I could get them easily, but I didn't ask where since I wasn't ready to throw down 600 for the tires.
They may have been knock offs of the vette wheels, but they looked great and just barely missed the Brembos w/ a small spacer. I plan on getting a set in chrome and will ask the question of where and get back to you guys.
Old 10-19-2010, 07:32 PM   #11
StealthSS
StealthSS's Avatar
Drives: 2010 2SS/RS Camaro - Black
Caverman you beat me to the punch.... I have been thinking about new tires this whole week after the drag strip last thurs. I have a few calls in to people about some cheap rims, I'll let you know what I find.
2010 Black/Black Camaro 2SS/RS (Airaid CAI, Street Scene Body Kit, Weather Tech Floorliners, Carriage Works Billets, Magnaflow Competition Exhaust, Kooks LT headers, Edlebrock E Force Supercharger, Snow Performance Methanol kit, Lakewood trailing arms/toe links, Eibach front and rear sways, Nitto drag radials)
StealthSS is offline   Reply With Quote
Old 10-19-2010, 07:52 PM   #12
nyny69
Drives: 2010 IOM SS
Thanks mlee
Old 10-23-2010, 03:28 PM   #13
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
PM sent...
It is a C5 Z06 Vette Replica wheel like this one... 18" X 10.5
Old 10-23-2010, 03:54 PM   #14
maxdmax
maxdmax's Avatar
Drives: 2010 Camaro SS/RS
I got a set of the wheels below for $285 each and mounted a set of MT 305/45/18s. Make sure you get the C6 ZO6 wheels with the 40MM offset, the others won't fit. I have not been to the track with them yet, my butt 60' times seem alot better. With the street tires I could not launch at more than 2,000 RPMs on the street and I would still make smoke if I went WOT in 1st. I tried a launch today at 3,500 RPMs on the street after warming them up and they held really well. My Gforce axles have been delivered and I am going to try a launch at around 4,500 RPM at the drag strip. Will know for sure on the 7th. I did not zip tie them back, I just used a couple of 1/2" hose clamps. I just pushed the line back through the little bushing an inch or so and then added the hose clamp behind it. This seems a lot stronger than a zip tie, doesn't bend the cable and you can't even see it.
http://www.corvetteguys.com/c6z06-ch...-18x95-40.html
LPE 417 - TVS2300 787 RWHP 759 Torque - Built by WWW.KYSPEED.COM
maxdmax is offline   Reply With Quote
