Drives: 2010 Camaro Join Date: Feb 2010
6 rib, 3.2 pulley with Maggie?
Has anyone been able to run a 6 rib 3.2 pulley without any belt slippage? I want to drop two sizes but were concerned about getting slippage. Just looking for some opinions or experiences. I'm trying to avoid converting to the 8 rib.
![]() Drives: Four Door Camaro Join Date: Apr 2010
I run a 2.9 on my G8 if that helps you
![]() Andy |
![]() ![]() ![]() ![]() Drives: Maggie blown LS3 vette Join Date: Aug 2009
2.9" here too. Only 8.5 psi though. I think you need to consider how much boost you'll be making vs how big the pulley is. You'll run into belt slip based more on boost level than pulley size. Boost = load on the belt (more or less). Let the engine breathe through cam and exhaust upgrades and you'll make more power with less boost. Less boost = less heat.
I'm at 10 psi right now and I know in my head that I shouldn't go for more boost on the stock bottom but it would be an easy way to make power....probably for a limited time.
The desicion for now is to drop the drag radials for 17" slicks and try again. The car was just overpowering the track and no sense of shooting more power to the ground before I can use what I already have. Thanks guys. |
#5 | |
Carguy
Drives: 57Chevy,67,80,2@10's camaro's,04SSR Join Date: Jan 2009
Crank pulley is 8 rib but don't need to use them all now. How are you getting fuel to that monster. I tried a 3.6 and ran out at 5800RPM had to go back to 3.8 until I solve my fuel problem. |
| DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 09:25 PM |
| Anyone know of a 10 rib Pulley system???? | jrpxxii | Forced Induction - V8 | 25 | 07-09-2010 01:40 PM |
| Quick question on tvs pulleys | boostedyards86 | Forced Induction - V8 | 19 | 04-29-2010 10:04 AM |
| maggie pulleys/boost | drkllr | Forced Induction - V8 | 16 | 03-24-2010 07:00 PM |
| Maggie with 7.5 pulley?? | steeleshark2 | Forced Induction - V8 | 2 | 02-21-2010 10:20 PM |
