How bad are burnouts?
How bad are burnouts for your car? for an auto trans. burnouts that involve holding the brake and gas simultaneously and then letting go of the brake. how bad is that for your camaro?
![]() ![]() ![]() Drives: '10 Camaro SS Join Date: Apr 2009
It's pretty hard on your brakes and puts allot of strain on the rear-end of the car. Press on the brakes just enough to keep you from moving forward, to much brake can/will break stuff.
Get a line lock and then it's just a tire problem...
2010, SIM, 2SS/RS, LS3, CGM Stripes
![]() Drives: 2010 Camaro 2SS Join Date: Apr 2010
I was wondering the same thing, thanks for the post I'll make sure I don't put to much strain on the brakes. I'm new to this burn out thing, but where can I get a line lock?
#4 | |
http://www.camaro5.com/forums/showthread.php?t=53548 Lot's O' Parts: http://www.camaro5.com/forums/showthread.php?t=14723
thanks much guys! whats a linelock?
#6 |
It's a device used to keep fluid pressure applied to brakes that allows the front brakes to lock independently of the rear brakes with a switch, allows easy burnouts.
#7 |
are the street legal?
#8 |
To be steet legal the brake lights must operate when the brakes are applied.
Here is a good write-up on how to properly install a line lock and keep it street legal with the proper wiring... http://www.allstarperformance.com/do..._Line_Lock.pdf
#9 |
thanks buddy!
| Tags |
| brake, break, burnouts, harsh, hurt |
| What song are you listening to right now | Muscle Master | Off-topic Discussions | 6760 | 11-08-2025 01:54 AM |
| Heatsoak as bad as LS2? | BackinBlackSS/RS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 19 | 05-09-2009 07:16 PM |
| Burnouts, the tire type? | cyberbro | Wheels and Tires Talk Sponsored by The Tire Rack | 5 | 05-05-2009 09:46 AM |
| bad fuel pump? | Looking Good in Red | 4th Generation Camaros | 27 | 04-21-2009 02:59 PM |
| Good Idea? Bad Idea? | cam2fst4u | Off-topic Discussions | 25 | 04-13-2009 08:06 PM |
