Old 04-26-2010, 11:51 PM   #1
AWS-GTAW
Drives: 2010 Camaro 2ss M6
Window hits when openeing door?
I have a problem on my 2ss camaro passenger side door/window.
When i open the door the top of the window seems to slightly hit the top of the window frame.
It seems as if the window mechanism that lowers its position while opening is slightly lagging in time, because if the door open slowly the window hitting problem does not exist. My drivers door/window does not have this problem no matter how fast i try to open it the window does not hit.
Is it normal for the very top of the windows to nick the door frame while opening? Has anyone with this problem take in there car to have this issue fixed?
AWS-GTAW is offline   Reply With Quote
Old 04-27-2010, 08:25 AM   #2
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
I've got the EXACT same issue on mine. I'll have the dealer look at it when I take it in for my first oil change (free for a year ) in about 500 miles.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 04-27-2010, 08:28 AM   #3
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
Have you tried reprogramming the window?
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 04-27-2010, 08:44 AM   #4
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
The window just needs to be adjusted. It is not an index issue, it is a window retainer adjustment issue. Simply bring it into the dealer and it will be covered under warranty. They will remove the interior panel and access the screws which hold the window tight in its holder. Then they will slide the window farther down (1mm) and you should be good to go.
Hylton is offline   Reply With Quote
Old 05-14-2010, 11:46 PM   #5
AWS-GTAW
So anyone went to dealer to fix this? My car spent the whole day at the dealership and they still did not finish the job I was told to bring it back next week cause i needed the car over the weekend.
Old 05-14-2010, 11:52 PM   #6
AWS-GTAW
Do you know if a special tool is required? The guy at service said that it did.
Old 05-18-2010, 05:21 AM   #7
AWS-GTAW
Well went back to the dealer today. They checked it out and both windows were to factory specs in height measurements. The passenger side still hits, so my dealer ordered a new latch "pop" Take the car in on the first of June.
Old 05-18-2010, 05:23 AM   #8
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
open your windows before you open the door....
no just kidding...
i hope they find a solution
AlSuwaidi is offline   Reply With Quote
Old 05-18-2010, 05:31 AM   #9
Pumpkin1LT
Drives: 2010 Camaro 2SS
I have this same problem, the dealership reprogramed it once and I've done it atleast three other times..it STILL does it. Just another thing to bring up when I take her in for the tranny.
Pumpkin1LT is offline   Reply With Quote
Old 06-27-2010, 11:43 PM   #10
Ohio5thgen
Drives: c6 corvette
Mine has this problem as well but it isn't causing a problem so I wont let the dealer touch it.
Ohio5thgen is offline   Reply With Quote
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 08:57 PM
HELP with Door lighting so Dealer gets right ttexxan 5th Gen Camaro SS LS LT General Discussions 3 01-18-2010 08:20 PM
HelP with Door lighting so Dealer gets right ttexxan Cosmetics and Lighting Modification Discussions 0 01-18-2010 08:03 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 05:58 PM
GM Bulletin HVAC system reprogram caused window problem VegasSS 5th Gen Camaro SS LS LT General Discussions 16 10-02-2009 02:10 PM
