![]() Drives: 2010 Camaro 2SS/RS Join Date: Jan 2009
Intermittent Noise from Front Right Side? Playing card against bicycle spoke sound?
I noticed a new odd sound coming from the front right of my car.
Only can be heard when car is in motion...specifically moving forward from a complete stop. It sounds like a playing card against the spokes of a slowly spinning bicycle wheel. As speed increases, so does the repetition of this sound. Not related to cold or hot starts and it doesn't appear to be the heater core tsb. Anyone else notice this? Perhaps something clutch related?
2010 Camaro 2SS/RS
Cyber Gray Metallic/Black |
![]() Drives: 2010 Chevy Camaro Join Date: Jul 2009
small rock in the tire tread or low tire pressure would be the first and simplest thing to look for but i'd imagine you already checked that.
it's my shell I'm the turtle
![]() Drives: 2010 Rally Yellow 2SS M6 Join Date: Jul 2009
Funny I have been hearing a similar sound over the last week or so (2SS m6). It sounds more like it is coming from under the console/shifter area though. Wife just said tonight when we were out that it sounded like a card in a bike spoke also.
gremlins
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
See if there are any stickers hanging off the driveshaft.
The DS has several bar code stickers on it, and if they come loose, it will sound just like a card flapping in spokes. |
#6 |
I didn't see any of the barcoded decals on the visible portions of the driveshaft. Could the decals be placed on the driveshaft portion hidden/covered by the heat shields?
2010 Camaro 2SS/RS
#7 | |
Okie doke
Crowley
#8 |
I did check all 4 tires while it was on the lift and there were no rocks in any of the tires.
The barcoded decal on the driveshaft is plausible. Next time its on the lift, I'm going to check to see if there is a decal on the ds around the shifter area. The search continues...
2010 Camaro 2SS/RS
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
Mine does this periodically (V6 M6). I had the dealer put it up in the air, and the mechanic and I looked at everything: tags, heat shields, rocks in tires, drive shaft bolts, etc. Mine does it with clutch in, clutch out, all gears, brake on , brake off, blower motor on and off. Couldn't find the culprit.
Then, a couple days later it just stopped. For about 3 months, nothing. Then it started up again a couple weeks ago. I may take it back just to document that it's still there.
1968 Camaro Convertible LS1, T56
#10 |
![]() Drives: EXT Join Date: Nov 2008
There are a ton of threads on this sound. Your dealer has a fix. I believe it is some new valve for HVAC??
#11 | |
I guess it can't hurt to ask about it, though.
#12 |
Anyone find the culprit here?
#13 |
There is a couple of clicking sound bulletins. One says to check the driveshaft for a bar code label that is half hanging off. There is another for adding a washer/spacer to an axle. I'd look close at the driveshaft for any hanging stickers, if not - I'd have the dealer look at it.
#14 |
460 RWHP 420 RWTQ
Same Here. Just noticed last night so this thread was timely.
| The Elimination Game: Camaro colors | Ant | Cosmetics and Lighting Modification Discussions | 2739 | 04-10-2014 09:37 AM |
| Got Pulled over... | TRSS2 | Cosmetics and Lighting Modification Discussions | 39 | 03-08-2010 11:57 AM |
