Old 04-28-2010, 03:48 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
Info on MTI Racing V6 shifter
We wanted to give you guys detailed pictures and description of the V6 shifter so you can see the quality.
We all know the V6 Camaro is no slouch, but the shifter is possible the weakest link in the equation. The MTI Racing Six Shooter Shifter for your 2010 Gen5 V6 Camaro will give you fast quick shifts and a great precise feel while still maintaining the every day driveability we all need.
Here is how we do this...
First things first, replace all the mushy feeling rubber bushings with high-quality Delrin bushings to improve the shifter housing and its attachment points. We also replace the pivot shaft with a better alloy.
Second, machine the shifter shaft out of very high quality stainless steel for strength and rigidity to help keep everything as solid as possible. The shifter stick is also threaded to accept either the stock knob or assorted aftermarket knobs, such as our MTI Racing Black or White Cue Ball.
Third, by using a high durometer silicon dampening material, we make sure that the shifter stick is quiet and precise.
Fourth, we engineered a roller bearing where the shift rod connects to the shifter. This ensures athe lowest friction available, while maintaining perfect tolerances. Because of these measures, the shifter gives the handler a super-smooth action.
My suggestion, play hooky, shift gears and take a weekday drive.
MTI Racing Kevin is offline   Reply With Quote
Old 04-28-2010, 07:10 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Very nice.
And we got your message. One of us will give you a call as soon as we get a second to breathe.
Old 04-29-2010, 08:44 PM   #3
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Are you able to retain use of the factory centering springs?
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 04-30-2010, 09:47 AM   #4
MTI Racing Kevin
Drives: 2010 Camaro
Yes, the factory centering springs will be used. This shifter is a direct replacement for the stock shifter without the mushy feel.
Old 05-07-2010, 09:14 AM   #5
MTI Racing Kevin
Drives: 2010 Camaro
BUMP
Old 05-23-2010, 05:11 PM   #6
El Diablo
El Diablo's Avatar
Drives: 67 Camaro rs/ 2010 Camaro SS/RS
The guys installed my shifter at C5F in my 2SS and it is a night and day difference. You know exactly where you are with this shifter.
El Diablo is offline   Reply With Quote
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 09:29 AM
MTI Racing Shifter Install bigd2010ssrs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 04-21-2010 11:19 AM
Shifter Party at MTI Racing MTI Racing Kevin Transmission / Driveline 12 03-01-2010 08:17 AM
MTI Racing Stage 1 Suspension Upgrade MTI Racing Suspension / Brakes / Chassis 0 01-27-2010 10:14 AM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 12:57 PM
