![]() Drives: LT CGM Join Date: Feb 2010
AAC Footwell lighting questions
What's the install like with these? Do you have to drill and tap it into something for them to work or what?
Also, what's the difference between the 12" and 15"? Why would you get one or the other?? |
![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS 50th Anv, 1972 RS Join Date: Mar 2009
Install was about 20 min. Tapped in to the dome light wire under the dash (see post #17 in link below for location). I have the 12" - lights up great. I just zip tied them up.
http://www.camaro5.com/forums/showth...light=footwell |
God Bless Dawson
Drives: Synergy for my Daughter Join Date: Feb 2010
It is a pretty straight forward install. Not complicated at all.
I've never done any upgrades though, so I'm a little weary.
I looked at some peoples instructions and it looks like you have to tap into the dome light and such... Is there anyway to just install them under the footwell and have a separate switch? I don't want it tapped into the dome light. |
God Bless Dawson
Sure you can just tap any hot wire and run the ground to the frame with a switch anywhere in that connection.
#6 |
![]() ![]() Drives: SSRS - black, GFX, SSX wheels Join Date: Aug 2009
My drivers side footwell light isn't mounted in a location that is protected as well as the passenger side. It sticks out a little more than the passenger side. Has anyone else noticed this or found a place to mount them that is more protected.
#7 |
![]() Drives: '10 Camaro, IBM 2LT/RS Join Date: Jun 2009
I just did my footwell lighting last week. The hardest thing about the install was the awkward positions I had to contort my body into to work.... Aside from that it's a fairly straight forward install.
I chose to go the route of tapping into the dome light, however it left me wanting more. I decided to get the effect I wanted I needed to throw in an on/off/on switch and tie the lights to a spare fuse in the fuse box (method is detailed by Justin from AACstyle somewhere on the forums) as well so I could also turn them on while driving. The one problem that presents itself is that the LED strips are very bright and somewhat distracting, so I also ordered a dimmer switch from oznium.com so I could control the brightness and give it a more subtle effect. I haven't seen anyone do this with their footwell lighting so I'll be sure to post pictures and possibly videos when it's done. Probably a little more work than you're looking for but for just the standard install it's not too bad.
[Insert obligatory car/order info below]
2LT RS; Imperial Blue Metallic w/ Silver Rally Stripes; Gray Leather Interior; Automatic; Exterior Painted Interior Trim Panels; Blue LED Footwell Lighting; Dash ABL; DRL Halos Ordered - 1/16/10 at Weber Chevrolet in Granite City, IL (Excellent experience; Thanks John!) Produced - 2/24/10 In the driveway - 3/4/10 Total time order to delivery - 47 days Last edited by binlow84; 05-02-2010 at 02:06 PM. |
| aac lighting | jordan 572 | Cosmetics and Lighting Modification Discussions | 11 | 05-27-2010 11:46 PM |
| Synergy Lighting Done By ACC | Shuffler | USA - Texas | 25 | 04-16-2010 01:15 AM |
| Footwell lighting | 1bad65 | 5th Gen Camaro SS LS LT General Discussions | 2 | 04-06-2010 07:47 PM |
| AAC Lighting install | Screaminz2002 | Cosmetics and Lighting Modification Discussions | 4 | 02-20-2010 04:08 PM |
| Footwell Lighting Question | BUMBLEBEE_SS | 5th Gen Camaro SS LS LT General Discussions | 19 | 02-09-2010 10:21 PM |
