Old 05-01-2010, 10:06 PM   #1
chrislhardin
Kalel7
chrislhardin's Avatar
Drives: 2010 Camaro LT2 Victory Red
Best aftermarket HID kit
What is the best aftermarket HID kit for the Camaro??
chrislhardin is offline   Reply With Quote
Old 05-01-2010, 10:23 PM   #2
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
Best is a matter of opinion. I have Oracle Bi-Xenon. No problems and they work great.
Shuffler is offline   Reply With Quote
Old 05-01-2010, 11:27 PM   #3
MaddawgXXXL
MaddawgXXXL's Avatar
Drives: 2016 Hyper Blue
Shuff... what does the bulb on your bi-Xenon look like? Is it one long bulb or two bulbs next to each other?
MaddawgXXXL is offline   Reply With Quote
Old 05-02-2010, 09:49 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
You can see everything here. This is the Bi-Xenon kit but no Halos.
http://www.camaro5.com/forums/showth...hlight=install
This should be the same install as BfXenon. I would use either AAC or BfXenon.
Build Journal
Old 04-14-2015, 05:44 PM   #5
Blackandwhite
Blackandwhite's Avatar
Drives: 2015 Camaro ZL1
I'm pretty sure the passenger side IS the side that's used to send the signals for the HIDS. I had HIDS from Xenonsupply and they were great and did pretty much the same exact install, except i used my positive for the relay from the fuse box bolt. Either way. I used the passenger side factory socket, just making sure it's not different for AAC
Blackandwhite is offline   Reply With Quote
Old 04-14-2015, 07:05 PM   #6
cadelennon
Drives: '15 Camaro 1lt,
please do not put hid bulbs in reflector housings designed for halogen bulbs it blinds everyone around you and its illegal.
either get rs headlights or look up how to do a hid protector retrofit
cadelennon is offline   Reply With Quote
Old 04-14-2015, 07:09 PM   #7
easyfame
easyfame's Avatar
Drives: 2013 Camaro LFX
tbh i've been blinded by WAY more projectors than halogen housed hids. It completely depends on the design of the headlight housing imo.
2013 1LS Black
Mods
MRT V2 Axle Back, Cold Air Inductions Intake, Vitesse Throttle Controller, 20" Voxx SS Wheels Matte Black, Blacked Out Bowtie, Side Markers, Taillight Bezels, Front Bowtie Delete, 1LE Suede Steering Wheel, Shift Knob and boot. 4-Pack Gauge Cluster, Fog Lights
easyfame is offline   Reply With Quote
Old 04-14-2015, 07:16 PM   #8
cadelennon
thats because people also put hid bulbs in halogen protectors...
or they have them aimed incorrectly. i have caught myself below the cutoff of an hid protector and it was pretty blinding.http://www.google.com/imgres?imgurl=...&client=safari
Camaro Brembo Big Brake Kit, Installed!! SS Mike Suspension / Brakes / Chassis 125 09-09-2010 01:34 PM
Edelbrock Supercharger Kit for 2010 Camaro Pre Order Special TitanMotorsports Forced Induction 51 04-01-2010 10:26 AM
Double Din Kit Stock Appearance Taking Orders Hess RS Audio / Visual / Electronics/ Gauges / Nav 30 03-14-2010 11:41 PM
Official $5999 Ultimate Performance Single Turbo kit for sale thread. JTinFL Forced Induction 30 10-21-2009 07:43 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
