Old 05-03-2010, 10:11 PM   #1
Burnt_RS
Burnt_RS's Avatar
Drives: '10 1LT/RS
dent in door
My car came from the dealer with a small dent on the pass. side door, right on the crease that runs horizontally, 2/3rds of the way up. The dealer said they would take care of it, but Im a bit nervous about letting them touch it. They have a company that does all of their dents, come in and do it. From what I can see, they will have to remove the door panel and inner panel then bang it out. It's a very small dent so the paint should be fine. In fact the dent is so small that it took me a few days to see it the first time. What do you guys think? I have watched the videos on removing the outer door panel and it seems easy enough, but I still have a feeling that I will get my car back with a loose door panel or a rattle in it. I've had enough headaches with my dealer, I just want the damn car to be the way it should have been when I picked it up. (I have more issues with the car too).
Burnt_RS is offline   Reply With Quote
Old 05-04-2010, 03:53 AM   #2
Makris
6.1L SRT8 for 6.2L SS <3
Drives: Camaro SS
i had a dent in my '06 charger and i attempted doing it myself...... i regretted it lol
my dad was a bodyman and i even had most of the tools, but its just a safer bet to get a pro to do it, i would let the dealer do it as long as they dont charge you
hope all goes well!
Traded SRT8 for 2SS... Greatest Decision Ever.
Makris is offline   Reply With Quote
Old 05-04-2010, 04:09 AM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I know this is kind of besides the point, but why did you buy a damaged car? I would've walked out the door and found somebody else who had one that wasn't dented.
At this point, let them do it. That way they are liable for whatever happens. It should be no problem if it's as small as you say. Speaking from experience, the door panels are very easy to remove/replace without any rattles. I had to take my passenger side one off four times one day while installing my projectors. No rattles noises of any kind. They snap on VERY snugly. Good luck.
Old 05-04-2010, 08:58 AM   #4
firstmate
firstmate's Avatar
Drives: 2010 Blk/Gry SS/RS M6
More than likely it will be paintless dent repair. I had one in almost the same spot you described (given to me by a fellow Camaro owner ), and had a place called Dent Wizard here in Houston come out to my work and they fixed it while it was in the parking lot. They had a tool that slid into the door panel between it and the window. It had a little "paddle" at the end of a curved rod. They rotated the bar and the paddle pushed the dent out from the inside of the panel. It is almost impossible to see where it was.
If I had to guess, they will probably be doing something like this, so your door panel probably won't even be removed. Just thought I would share my experience with the similar issue and how it worked out for me.
Thanks and good luck to you!!!
Ordered 10-13-08 2SS/RS M6 BLK/GRY
VIN #2386
Delivered 6-11-09 - Woo Hoo!!!
Hey Houston locals--------
Join the H-Town Camaro Club
www.H-TownCamaroClub.com
firstmate is offline   Reply With Quote
Old 05-04-2010, 10:24 AM   #5
JB @ C and L Machine
Drives: Ordered 2011
Don't do yourself!!! You will make a mess of it!!!!! Have the right pro do it as they can do it in about 15 mins with taking anything apart. I had it done on my 06 charger and 08 Tow truck. I used the same guy both time and it was only $50 and $75 bucks. Well worth it and you cant even tell there was anything done.
Jay
JB @ C and L Machine is offline   Reply With Quote
Old 05-04-2010, 11:12 AM   #6
Coop 2010
Delivered 05/20/2009
Coop 2010's Avatar
Drives: Black 2010 2SS RS
They will drill a small hole in the inside edge of the door (where the latch is) and run their tool into the hole. They put a plug in the hole when finished. I'ts a very small hole. They will have the dent out in aobut ten minutes. They don't make enough money to R&R your door panel. There is no "banging " to remove the dent, they just massage the area carefully and work the dent out.
Coop 2010 is offline   Reply With Quote
Old 05-04-2010, 02:02 PM   #7
DetailAddict
Drives: .
PDR guy don't usually remove door panels and they don't always have to drill holes. It makes it easier, but you can always tell them don't drill and they'll just have to spend extra minute or two if it's just a small dent...
DetailAddict is offline   Reply With Quote
Old 05-04-2010, 02:25 PM   #8
Dave2SSRS
Dave2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
Tell the dealer you want the body shop to repair it. No paintless dent repair. The dealer owes you this!
2010 Camaro 2SS/RS
Imperial Blue | Grey two-tone Interior | Silver racing stripes | Magnaflow Comp Cat-back | CAI intake | Elite Engineering Tunnel Brace |
Richmond (Houston), TX
Dave2SSRS is offline   Reply With Quote
Old 05-04-2010, 05:04 PM   #9
Burnt_RS
Burnt_RS's Avatar
Drives: '10 1LT/RS
The dent is VERY small and because of this I didn't notice it until after I had the car for a few days. I might have decided differently when I picked it up, if I had noticed the dent, but even if I did notice it. There was no other car instead. This car had to be delivered from a dealer on the other side of the province (and was one of two 1LT RS M6's in the province that had the options that I wanted: none . I wanted IOM, the other car was silver) and I didn't want to have to play the waiting game to see if another came in, as it was after the deadline for 2010 factory orders.
Yes, the dealer is going to cover it 100%. I made sure of this. At first they weren't too quick to offer assistance with it, but some voiced concern on my end got them in line. haha
hope all goes well!
I wasn't thinking of doing it myself, I was merely explaining that I see how simple it looks to remove the door panel - I was unsure of the ability of some people that might be touching my car. I guess I should give the professionals the benefit of the doubt, but this is my baby so I'm obviously going to be over protective.
thanks for the responses guys This forum rocks!
Old 05-04-2010, 09:08 PM   #10
Yellojacket
Yellojacket's Avatar
Drives: 2SS/RS Inferno Orange
I had a decent dime sized door ding in my passenger door right on the crease and I also used Dent Wizard paintless dent repair and within 10 minutes of working the tech had the dent completely removed. I've looked over the door from every angle in different lighting and I can't tell where the dent was AT ALL. Paid the guy $60 in cash and all done good as new.
Yellojacket is offline   Reply With Quote
Old 05-04-2010, 10:18 PM   #11
Batman0837
Drives: '10 CGM 2SS/RS # 71394
Terrible advice!! PDR is the way to go, as long as the tech is adept at his craft you'll be fine. Why devalue the car by painting it unnecessarily just because the dealer "owes" him ? I would not recommend allowing the PDR guy to drill though, It is just as easy to go down the window and repair w/o drilling!! Drilling is ALWAYS a last resort and should not be done to speed the repair or make it easier for the tech...
Batman0837 is offline   Reply With Quote
Old 05-05-2010, 06:38 PM   #12
Burnt_RS
Burnt_RS's Avatar
Drives: '10 1LT/RS
My dealership uses a local dent removal guy for all of their cars. It's supposed to be paintless dent removal for this dent.
Old 05-05-2010, 06:44 PM   #13
myerardi
Drives: infiniti G37; 2010 SS/RS RJT
I just bought a RJT and noticed a dent Exactly where you are describing. dealer had dent man from out of town who comes weekly to fix it. He did it from inside out. Now impossible to see the dent! So slick. If your dealer has this kind of pro on retainer, go for it.
myerardi is offline   Reply With Quote
Old 05-05-2010, 09:35 PM   #14
Burnt_RS
Burnt_RS's Avatar
Drives: '10 1LT/RS
Just talked to the guy. He said he puts a protector over the window, after putting it all the way down. Then he goes between the window and the outer panel and works the dent out. He said it would take maybe 15 mins. No panel removal required, said he does this all the time. Better yet is that he is coming to my house to do it, since he is based out of the town next to me, instead of both of us driving even further to the dealership.
DIY: How to Change the Door Speakers RandyB Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 15 04-26-2014 11:53 PM
New Camaro based concept - - - 4 door coupe AlSuwaidi 5th Gen Camaro SS LS LT General Discussions 64 05-12-2010 09:55 AM
anyone ever have issues with doors not opening? j0hnny007 5th Gen Camaro SS LS LT General Discussions 4 05-01-2010 01:36 PM
Passenger Door Leaking? Seawolf 5th Gen Camaro SS LS LT General Discussions 10 02-06-2010 11:56 PM
ambient lighting on drivers door is defective. edog Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 08-10-2009 08:07 PM
