![]() Drives: 2SS/RS Summit White Black Stripes Join Date: May 2010
How to remove the rear bowtie
I was wondering if anyone knew how to remove the bowtie in the back because i want to put a black vinyl under it but in order to do that i need to remove it but how?
Drives: 2010 Challenger R/T;2011 Mustang GT Join Date: Jan 2010
Carefully.
When I did mine I used a small flat head and worked around the edges. I then focused more on one edge working further towards the center until I could pry with my fingers. Be very careful as you can damage the paint easily. ![]() Pull on the badge and never pry against the paint. |
NCM-WINR
Drives: 2010 SS/RS IOM 2014 2LT Stingray Join Date: Mar 2009
I used a putty knife very carefully
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
I've heard a blow dryer to heat then use some fishing line. Never tried it though.
sounds great this is what i want to do but now once i get the vinyl back on how to i get the bowtie back on and centered the right way?
http://www.camaro5.com/forums/attach...1&d=1249394655 |
#6 |
let me rephrase that because i re-read that and was like wth? ok this is what i want to do to the back of my camaro http://www.camaro5.com/forums/attach...1&d=1249394655 now after i remove the bowtie and place the vinyl on how do i put the bowtie back on over the vinyl in the centered position anyone have any thoughts to this please help any info will be great
#7 | |
www.Camaro5store.com
Take the wife's hair dryer and tell her, "it'll be okay, honey...I'll give it right back." ![]() Get some fishing line and if you don't have any, dental floss works just as well. Heat up the bowtie and don't worry, it'll be fine. Heat it up and while doing that, start working the fishing line behind the bowtie. The fishing line will cut right through the adhesive tape that holds it on and your bowtie will come right off. Just get some 3M adhesive tape to put it back on. |
#8 | |
![]() Drives: 2011 1SS Join Date: Mar 2010
Once the bow tie is removed. There are 2 holes in the trunk. These can be used To recenter bow tie. Left hole is bigger than right hole. Not sure why this is. Kinda wiss there wasn't holes in the trunk. I would have left my rear bow tie removed. |
#9 | |
Capt. Organization!
Drives: Black 2010 2LT/RS Camaro Join Date: Apr 2010
BUT, before you do that, take some painters masking tape and using the original Bow Tie, mask out it's location with a tape rectangle or something to help you line up the new Bow Tie where it belongs. Hope this helps!
>>>Rhode Island Chevy Show<<< June 29, 2014 - What better way to get a sig pic!
>>>Pit Girls @ Angry Hams<<< July 2, 2012 - What better way to get a hot girl pic! |
#10 | |
![]() Drives: 2010 camaro Join Date: Jan 2010
#11 |
thanks everyone i appreciate the in put so once i get the bowtie off i need to buy 3M tape put it on the bowtie then put it back on right
#12 |
![]() ![]() Drives: car Join Date: Feb 2010
Roger that!
#13 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LT RJT Join Date: Feb 2010
i used a hair dryer and fishing string. Didnt attempt to pull with my fingers either until i loosened up the center. once i was able to get enough space between the trunk and the locating pins, i slid the string between it so that i could seperate the center of the bowtie from the trunk. after i did both sides and the center, it just popped off with ease. Once its off, clean the area very well, use some alcohol to take off whatever is left of the old 3M tape, apply the new 3M tape to the back of the bowtie, and stick it back on.
One other note, before i pulled off the bowtie, i used masking tape so that i would have a reference of where it was originally placed, its also good for determining if its level or not. you dont want to put it back on crooked or slanted! |
#14 |
![]() Drives: 2010 2SS RS Red Jewel Tint Join Date: Apr 2010
Been reading the how-to advice. Thanks all, since I have a similar project planned: Black out, then replace bow tie with an SS emblem. Got decal and emblem, and hope to do soon.
| Shaved bowtie and Rear Blackout | showstopper | Cosmetics and Lighting Modification Discussions | 35 | 01-17-2011 08:56 PM |
| How does the rear bowtie emblem come off? | bumblebeecamaro | Cosmetics and Lighting Modification Discussions | 13 | 01-23-2010 12:57 PM |
| Has anyone considered modding the rear bowtie to be a tail/brake light? | BarticusRu | Cosmetics and Lighting Modification Discussions | 2 | 01-08-2010 10:58 PM |
| Steering response.... | CGM2SSRS | Wheels and Tires Talk Sponsored by The Tire Rack | 130 | 10-21-2009 05:04 PM |
| Red Front & Rear Bowtie emblems | RPO687 | Cosmetics and Lighting Modification Discussions | 4 | 09-24-2009 08:34 PM |
