Old 05-05-2010, 11:16 AM   #1
DarkNight
DarkNight's Avatar
Drives: 2010 Camaro 2SS/RS
CEL Code after Supercharger Install L99
Has anyone out there had any problems after a Maggie Supercharger install
with trouble codes, P3401, P3425, P3441, P3449 ??? I believe these are related to the DOD stuff on an L99. Cyl Deactivation codes
I can't find a cure or the problem, any help would be greatly appreciated.
Thank you!
DarkNight is offline   Reply With Quote
Old 05-05-2010, 12:32 PM   #2
SonnyakaPig
Drives: C63 P31
What is the build date of your L99?
I'm sorry you're having these issues. I don't know what these codes mean, but I'm wondering if the tuning device that was used on your ECM wasn't compatible with your operating system. Some of the newer build date L99's are having this problem.
SonnyakaPig is offline   Reply With Quote
Old 05-05-2010, 01:56 PM   #3
Jon@MagnaCharger
Jon@MagnaCharger's Avatar
Drives: Anything Supercharged
DarkNight,
When you installed the supercharger did you change the valley cover? Only the LS3 requires you to do so. The factory valley cover is retained on the L99 to keep the DoD system. If you didn't change the valley cover then you more than likely knocked the DoD plug off of its connector when you slid the blower unit into place. If you reach back there and find the plug disconnected just reattach it. You might need to trim the top of the tab because of there is an excess amount of material on top of it.
Jon Barrett
MagnaCharger
Jon@MagnaCharger is offline   Reply With Quote
Old 05-05-2010, 03:13 PM   #4
Cole@Fastlane
Cole@Fastlane's Avatar
Drives: 2010 LSX shootout champions
Thank you!
If there was no cam installed and only maggie my money is on the rear DOD sensor was left unpluged.
3401 is cyl 1 deactivation
3425 is cyl 4 deactivation
3441 is cyl 6 deactivation
3449 is cyl 7 deactivation
Cole@Fastlane is offline   Reply With Quote
Old 05-05-2010, 03:15 PM   #5
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
With no Cam installed he's got bigger issues!
Good luck, hope these guys got your answer.
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
Old 05-05-2010, 03:46 PM   #6
Cole@Fastlane
no not really.ive seen this before and that was the problem.
Old 05-05-2010, 03:52 PM   #7
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
I was just kidding about not having a cam. Hard to open valves without one
Old 05-05-2010, 04:53 PM   #8
Cole@Fastlane
hehefunny guy
Old 05-06-2010, 02:10 PM   #9
DarkNight
DarkNight's Avatar
Originally Posted by Jon@MagnaCharger View Post
DarkNight,
Jon Barrett
MagnaCharger
Jon your my new best friend!!!!!!! Thank you!!! You were right the connector on the DoD was off and I did have to modify the clip to get it to go on and stay on.
All is good now......... I knew C5 would have the answers
Old 05-06-2010, 05:30 PM   #10
Jon@MagnaCharger
No problem! Glad I could help. And don't worry - you aren't the first person to knock that connector off and you won't be the last .
Jon Barrett
MagnaCharger
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
Vortech Supercharger install is complete... IConnection Forced Induction - V8 30 04-28-2010 10:16 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
HELP! Fuel malfunction code after CAI install scomaro22 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 01-17-2010 06:19 AM
