Old 05-06-2010, 10:51 PM   #1
2010ABM
2010ABM's Avatar
Drives: 2SS/RS ABM Camaro
Floating the Gears?
So, I experimented with "floating" the gears in my M6 SS today. Seems rather easy between 1800 and 2000 to slip it right into gear. However, I got to thinking...does this do any damage to the synchros in the tranny?
2010ABM is offline   Reply With Quote
Old 05-06-2010, 11:16 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
do u mean shifting without using the clutch?
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 05-06-2010, 11:21 PM   #3
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
If thats what he means. Then yes it will over time cause problems. If not sooner.
9/26/09 Took delivery!
Old 05-06-2010, 11:24 PM   #4
Camaro2SSLS3
Drives: 2010 Camaro 2SS LS3 6 speed IOM/IOM
I'v been doing it to all my cars over the past 10 years (still own my first car and drive it too) and never had any trans issues, as long as your not grinding gears and it goes in to gear like butter, no damage will be done. You need to match the rmps with your speed and it will fall right in.
Camaro2SSLS3 is offline   Reply With Quote
Old 05-06-2010, 11:47 PM   #5
2010ABM
2010ABM's Avatar
Yep! It seems to fall right into gear, no grinding or anything. I can't see it messing up the gears, only perhaps the synchros.
Old 05-07-2010, 06:57 AM   #6
cdn2usa
cdn2usa's Avatar
Drives: 2010 2SS
I know it is not exactly the same. Way back when, my 2nd car was VW Bug, drove that sucker without a clutch for a year. Would start it in gear and shift without any problems. It got to be a pain at lights and hills (using the parking brake).
I wasn't a wrench back then, so it took me a year to actually check why I didn't have a clutch. Turns out the adjustment wing-nut by the bell housing had simply fallen off. Less than a buck and in 15 minutes the clutch was working again.
Aqua Blue 2SS c/w factory white strips, MT.
Installed options;Tinted Windows, De-badged,
Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera.
cdn2usa is offline   Reply With Quote
Old 05-07-2010, 08:28 AM   #7
GNVenom
Turbos. Turbos. Turbos.
GNVenom's Avatar
Drives: 2010 SS Yellow/Black
You won't hurt anything as long as you don't clash the gears. Basically you are matching the engine speed with the driveline speed in a given gear. The clutch will live forever if you do it forever..but technically you can't.
I always slip the trans out of gear into neutral when I slow to a stop. If you feather the throttle it slips right out. And, if you don't actually have to come to a complete stop, you can easily slip it into first gear. Just beware if you miss your "opportunity" you'll clash the gears. Then, go back to basics.
John Spina
Caspers Electronics Inc.
Loveland CO
2010 2SS/RS Yellow/Black > http://www.bummlbe.com
GNVenom is offline   Reply With Quote
Old 05-07-2010, 09:52 AM   #8
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
As soon as you know what the rpm differential between gears is you can upshift or downshift without using the clutch. The key is to have it slide in and out of each gear with no sound or feeling in the stick. Done properly I don't see how this can caise any damage. If it is done wrong or forced, that's a different story.
Old 05-07-2010, 11:11 AM   #9
BigMatt
BigMatt's Avatar
I'm too afraid of messing something up to even try doing this.
Old 05-07-2010, 11:41 AM   #10
EB&D
EB&D's Avatar
Drives: '10 CGM SS/RS
Did it in my Jeep for the entire 12 years I owned it...never had a tranny isssue. Do it now in the SS as well. As long as it falls into gear with no ammount of force needed, you're good to go.
EB&D is offline   Reply With Quote
Old 05-07-2010, 11:57 AM   #11
cool
Old 05-07-2010, 12:46 PM   #12
LazyYoYo
Yep, that just happened.
LazyYoYo's Avatar
Drives: Norma Jean, '10 Black 1SS/RS
i suck at this.... always miss
K&N CAI
Doug Thorley Shortys
Solo High Flow Cats
Flowmaster American Thunder Catback
BMR Stage 1
JRE Tune
LazyYoYo is offline   Reply With Quote
Old 05-07-2010, 03:36 PM   #13
talltom
talltom's Avatar
Drives: Silver LS
That's just hilarious!
Silver LS - manual, white stripes, black interior, and those swell 18" black steelies! (18" Bavarian aluminum in the garage).
talltom is offline   Reply With Quote
Old 05-07-2010, 03:44 PM   #14
GSUNCSU
Watch This!
GSUNCSU's Avatar
Drives: Super Charged 1SS/RS, M6, CGM
Why do this?
K&N CAI, Wet Okole Seat Covers, MagnaFlow Street Perf. Ex. (Axle Back), MPD Hood, Gary's Customz ZL1 Fascia/Vented Fenders/Custom Stripes/Paint, AAC Afterburners/Fog Light Halos/Side Markers/Misc LEDs, Bee-Otch Air Freshener, Hurst Shifter and Line-Loc(APEX), RPI Splash Guards, MagnaCharger (Texas-Speed)(Installed by ME), Rx Catch Can and Breather, Billet Pulleys (SC2150), ARH Headers, LPE Twin Fuel Pump, Custom Blower Cam, Custom Tune TBArwhp, TBArwtorq, Boost Gauge and Single Pod (MTI)
GSUNCSU is offline   Reply With Quote
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
Richmond Gears V8 and V6 - Group Buy ZZcamaro Transmission / Driveline 175 04-30-2010 01:29 AM
MTI Racing Review (Camshaft, Gears, Suspension, Handling) Deric884 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 04-14-2010 09:11 PM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
Motive Gears says no Camaro Gears ZZcamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 60 01-07-2010 03:47 PM
