Old 05-08-2010, 10:59 PM   #1
jhutch
Drives: 2010 2SS ABM -Sold
Noise from rear end
When I start to move from a stop, and left the clutch out and press the gas, I get an grind/vibration (wheezing) from what sounds like the rear end.
happens only when I am coming out of a stop or slow roll.
I have a 2SS MT6
2016 Hyper Blue 2SS M6 White Interior Mag Ride NPP GFX
jhutch is offline   Reply With Quote
Old 05-09-2010, 10:18 AM   #2
gmman85
Drives: 2SS/RS/M6 Vict. Red/ Blk. Stripe
I have the same thing. Do you hear it more when you are in 2nd of 3rd and you take off at low speeds, thats when i hear it and all the time when i do 1-4 shift option which i reallly don't do anymore cause it sounds rough after you shift to 4th and try to take off.
gmman85 is offline   Reply With Quote
Old 05-09-2010, 09:34 PM   #3
jhutch
1-4 sounds bad (skip shift) all the time, rpms drop tooo low. I hate the skip shift
I only get the noise in 1st gear
Old 05-10-2010, 03:59 AM   #4
AWS-GTAW
Drives: 2010 Camaro 2ss M6
I have this noise kinda sounds like a vibration rub noise coming from the passenger rearend I think its the exhaust baffles on the muffler, I heard there is a recall our something i read here. When i go in to service for my window hitting I am going to bring this up also the problem with loose e-brake.
AWS-GTAW is offline   Reply With Quote
CTS-V rear end? VADER SS L99 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 03-01-2010 03:04 AM
Rear end gears 2Fast4U2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 01-26-2010 07:27 PM
lingenfelter package with stock transmission / rear end? okyankee Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 09-11-2009 01:10 AM
88 gta disc brake rear end wilnot 3rd Generation Camaros 0 08-26-2009 03:23 PM
Front end noise Chevy Jim Wheels and Tires Talk Sponsored by The Tire Rack 2 07-01-2009 03:12 PM
