Old 05-11-2010, 07:27 AM   #1
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Widening back of stock SS rear wheels
Is it possible to widen the back section ( brake side ) of a stock SS rear wheel ( 20x9) ? I was thinking of widening it 1" to a 20x10 and running 305/35/20 PZero's. From underneath the car it appears there is plenty of clearance between the tire and inner fender well. Any suggestions ?? Who would be the best to have the stock wheel widened ?? TIA .....Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 05-11-2010, 07:32 AM   #2
NinoSS
Drives: 2SS/RS CGM LS3
This has been done... and you will find. Use key word "widened wheel" or "widened rear wheel"...
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 05-11-2010, 09:23 AM   #3
flht99b
flht99b's Avatar
Yes, went through all those threads before I posted. In most of those threads it seems the front wheel was widened to 10.75" and .89" thick hub centric spacers are used. This is ideal for 315 tires.
I do not want to run spacers and I believe a 10" rim width is sufficient ( experts chime in ) for a 305/35/20 PZero tire.
Ed M.
Old 05-11-2010, 09:54 AM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Yes you can do what you are wanting to do. I'd contact someone in your area that specializes in widening wheels and go for it ..
I'm guessing your 305 tire will fit on a 10" rim with no issues, but it looks like they are recommending 10.5" - 11.5" ..
http://www.tirerack.com/tires/tires....rtnum=035YR0P0
Crowley
Crowley is offline   Reply With Quote
2010 Camaro wheels 10.75 " wide rear ADM PERFORMANCE Wheels / Tires 56 10-17-2012 10:00 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
Rear Stock Red SS Logos Pitttbulll Cosmetics and Lighting Modification Discussions 1 09-26-2009 07:20 PM
