Tap Shift, are you using it and how do you like it?
Well I am kind of getting tired of when I want the car to move it revs up and then drops a gear and goes. I just started to play around with the tap shift to get the car to move quicker.
How many of you are using tapshift most the time and how long did it take you to get the hang of it? I am sure my mileage will go down but if it makes the car more fun might be worth it. I know I know should of got the M6, but to late now. |
I use my tapshift all of the time, I love it.
#3 | |
Then, once you tune it, the A6 will be VERY fun and quicker and harder. PS - Any delay you're noticing is not the shift speed. It's from the computer recognizing your input. With that said, it's still accelerating during that "delay". I don't feel any type of delay anymore with my tune. You can blame torque management for the stock delay however. But, even with the delay on a stock tune, when it shifts IT SHIFTS. The delay isn't the car shifting, remember that. Hope that wasn't confusing.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
never use tap shift.shifts too slow.i use sport mode.
(-)1
It seems like no one reads my posts.
#6 |
I read it.
#7 |
on way to work use sport mode.
on way home Sport mode and tap shift. with Nanny controls off in good weather. Had 2010 on road corse but track was wet all day used sport mode and took stability control off. next time out will try using tap shift with stability off. |
#8 |
![]() Drives: 2010 Camaro 2SS RS Silver/Blk Join Date: Sep 2009
StlRomAniaN,
You're the first I've heard that experienced better tap shift response time with a tune. What tuner did you use since that is another nice benefit!! |
#9 |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
TapShift is a blast. 2/3 of the time I drove the SST, I used the TapShift. Get the A6 set up right and chirping the first couple of shifts gets your blood pumping...
#10 |
A guy at Redline Performance. Very knowledgeable guy and he's an expert with LSX engines. Another plus is that he takes his time tuning and gets everything just right.
#11 |
Starting to mess with the tap shift, but last car was a 6M CTS DI... hard for me to think about shifting without trying to step on the clutch.
Sport Mode + Comp Mode is getting me to redline just fine for my daily driving.
#12 |
For any doubters out there, just drive it through a bunch of up and down twisties (roads) and you'll be amazed. You can't downshift and upshift that quick in and out of turns.
#13 |
Motor Head
Drives: CTS-V Join Date: Feb 2009
Tap shift is fun to play with sometimes. I would rather have it on the console so it could be used in turns.
The better option is a trans tune. I left D mode as the factory set it. After 40 or so trys, I have S mode so it is truely an agressive street car. And, I have the 3.45 gears - WOW!
History Camaro's: 83, 93, 95, 98, & 10.
#14 |
Camaro & Stang Enthusiast
Drives: 2011 Mustang 5.0 in Kona Blue Join Date: Mar 2008
What post?
....kidding.... I read it too. But I have a manual
Bought my Camaro from Eric Hall(817) 421-7266
