![]() Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1 Join Date: Oct 2009
SCT Tuner problems
I finished installing a maggie, when I attempted to install the
Magnuson tune the SCT tuner could not read the stock tune. It showed a 1017 error message. Any ideas what this error message means? I did have a Vector tune, but I reinstalled the stock tunes before I used the SCT tuner. My car is an automatice |
![]() Drives: Soon to be 2013 ZL1 Join Date: Sep 2009
Check to see if it's unmarried. You need to hook it up to the car and download the stock tune to the tuner first. Then select the pre-programmed tune which is the maggie tune. Hope this helps.
Thanks for the help, but the tuner still can not unlock the stock tune. I will have to
check with Vector to see if they can help. |
![]() Drives: Anything Supercharged Join Date: Apr 2010
Quinthawk,
I talked with our tuner and he said that from what he has seen that Vectors tuner leaves something in the ECU that prevents its maps from being read (even the "stock" reflash) and that even a dealership might not be able to reflash it back to a fully stock program. He recommends calling Vector to see what they say about unlocking the ecu so that our tuner will work with it. Jon Barrett MagnaCharger |
![]() Drives: corvette Join Date: Oct 2009
#6 |
Black Thunder
Drives: 2010 Camaro 2SS/RS Join Date: Oct 2009
I had a Vector tune on my car before I installed my E-Force S/C. I had no problem returning it back to stock and then putting on the SCT tune. But yes I would call Kirk he is awesome with customer service!!
JRE 416 9:1 Forged Stroker Package
Edlebrock E-Force Super Charger JRE Blower Cam package Cooling Mist Water/Meth 3.25 blower pulley FAST 65 lb. hr. injectors JRE Edelbrock fuel system upgrade GM ZR-1 Clutch Roto Fab CAI Kooks Headers Jet Hot Coated Kooks High Flow Cats 3" Magnaflow Stainless Steel Exhaust Barton Short Throw Shifter JRE Dyno Tune |
#7 |
thanks for the help
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: everyone crazy... Join Date: May 2009
Isn't this illegal for a tuner to lock a customer's ECU? Why the hell would a tuner do this to someone's property?
If so, I guess from now on, anyone who is getting a tune, better get a written confirmation from the tuner that there no lock BS is involved. |
#9 |
Petro-sexual
Interesting...
Good luck though and I hope it works out
#10 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I guess some Tuners feel the need to Lock the ECM so other Qualified tuners Can't read and see what they do in They're tune, which is a Joke among the tuning community, the truth is there is no Black Magic in Tuning if your a True Tuner. I have never, nor will I ever Lock my Tunes.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#11 | |
I sent Kirk a PM regarding this post and the other one. Hopefully he can clarify. Last edited by Luvpilot; 05-19-2010 at 12:19 AM. |
#12 |
![]() Drives: 69 Camaro BBC Glide Join Date: Jan 2010
Definitely not something that is illegal to do and definitely something some tuners feel the need to do to ensure their customer isn't going to alter the tune because they feel they read a couple of internet web forums and are now officially tuners.
I do disagree though with completely locking yourself out of the tune. The end user should have the ability to flash back and forth between the stock file and the modified file. You shouldn't be able to edit the tuners final tune without a good explanation imho. I can see the argument go both ways. Regardless though, we don't lock our customers out of their tunes either. We do however charge double if you screw something up after "we told you so" jkNick |
#13 |
Kirk at Vector emailed me an updated version of the software that will hopefully
allow the Magnuson tune to be installed. |
#14 | |
| LSR Cold Air Intake + SCT Tuner - Special Pricing | Meister@Torq | V8 Bolt-Ons & Tunes | 2 | 05-03-2010 09:06 AM |
| SCT X3 tuner for sale, or trade! | MadMav | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 6 | 04-08-2010 05:04 PM |
| Got SCT Tuner and............. | sixty9fordkiller | Tuning / Diagnostics -- engine and transmission | 2 | 03-18-2010 09:52 AM |
| SCT Tuner question | JustaCamaro | Tuning / Diagnostics -- engine and transmission | 3 | 02-28-2010 07:32 PM |
| SCT Tuner For the V6 | GangGreen | Tuning / Diagnostics -- engine and transmission | 3 | 11-04-2009 05:23 PM |
