Old 05-16-2010, 03:59 AM   #1
Buhmblbe
Growing Up=Optional
Buhmblbe's Avatar
Drives: 2010 Camaro Transformers 2LT RS
Firewall Passthrough Found...Don't Drill!
I was tinkering around today to figure out some wire runs (Inspired by Wizzer)and I found this firewall pass through on the driver's side today. I have the 2LT, not sure if this is present on the other models. Bear in mind I am a total novice who has never done any of this before so I think I just got lucky:
1-From the engine compartment look up and over where the 12V cable comes into the engine compartment from the battery(The red cable wrapped in the white tape is the 12V cable) Notice the hole above it in the picture. It's pretty tough to actually see because it's up so high. I took the pictures with my cell phone tuucked way in there.
A zoomed out view to better orient you. The "wire" I'm holding in my fingers higher than the red 12V cable is actually my snake/fishing cable coming out from inside the car.(I have no idea what the corrugated tube thingy holds)
2-This is the inside view under the driver's side where the 12V power cable goes through from the inside of the car to the engine compartment.(I had to lie down upside down on the driver's seat in order to find this) After pulling back on the soft liner(There was one plastic cap I unscrewed to make removal easier) way up high over where the left foot rest thingy is you'll find a black rubber plug/fill-in thingy. Pull that out and Voila...the hole now pictured just above the red power cable will pass right through to the hole inside the engine compartment. No drilling needed(too bad considering I'm a dentist)
I hope I explained this clearly enough. If not just let me know and I'll try to take better pics or whatever, but now you know...no drilling required. (It goes without saying that grommits should be installed to avoid cutting the wires on the sheet metal).
"Sleep is an inconvenience to living...Get up and start living."
Buhmblbe is offline   Reply With Quote
Old 05-16-2010, 11:12 AM   #2
Rookie13
Hooked on AutoX
Drives: 1SS/RS
Send a message via Yahoo to Rookie13
Nice find - I can see/feel the same hole on my 1SS just above the Red Battery Cable. There is a plug on the engine side as well.
_________________
Rookie13 is offline   Reply With Quote
Old 05-16-2010, 06:05 PM   #3
Buhmblbe
Growing Up=Optional
Buhmblbe's Avatar
Wow. There was no plug on the engine side on my 2LT. Maybe it was another cost saving factor for GM on later production cars. I was in the 84K range.
Old 05-16-2010, 06:48 PM   #4
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Did you check to see if there was the one that I discovered under the cowl on the passenger side?
skuttduck is offline   Reply With Quote
Old 05-18-2010, 10:28 PM   #5
cfcoates
Drives: 2010 Camaro CGM 2SS/RS
You just saved my day! Thanks a ton for this great find!
Kenne Bell 2.8 Polished & Black - Coolingmist Methanol Injection
Stillen Front Splitter - Havoc Side Skirts & Rear Diffuser
ICONZ Wheels & Nitto NT-05's - PFADT Springs
cfcoates is offline   Reply With Quote
Old 05-18-2010, 10:46 PM   #6
ron10
Drives: 2010 2SS IOM L99
thanks for posting.
Old 05-23-2010, 08:46 PM   #7
Buhmblbe
Growing Up=Optional
Buhmblbe's Avatar
You're welcome
Old 05-25-2010, 09:23 PM   #8
Wizzer
Drives: 2010 Cyber Grey
Nice job. I'm sure I'll be running something through that also. Never can have enough holes to fill I always say.
Wizzer is offline   Reply With Quote
Old 05-26-2010, 01:02 AM   #9
AuSStinVRCamaro
Drives: 2010 Victory Red Camaro
Where does the wire come in again? I wasnt completely understanding where the wire comes into the cabin? Thanks
AuSStinVRCamaro is offline   Reply With Quote
Old 05-26-2010, 08:32 AM   #10
skuttduck
skuttduck's Avatar
Look under your steering wheel and up where the main battery cable comes in. He took the picture of this area with the plastic plug out, which was the last picture in the series.
There is a similar plug on the passenger side under the cowl.
http://www.camaro5.com/forums/showthread.php?t=80843
Old 05-31-2010, 11:52 PM   #11
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
thanks bud, it came in very handy installing my shift light!
moiy1983 is offline   Reply With Quote
Old 07-04-2010, 05:19 PM   #12
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
thanks for posting, this will come in handy soon!
IamJacksCamaro is offline   Reply With Quote
Old 07-06-2010, 10:54 PM   #13
camaro2lt
camaro2lt's Avatar
ITs in my 2lt vin#10325
Old 08-07-2010, 04:09 PM   #14
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
Awesome. Needed this hole today.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Who wants 23 free Camaros? Dr. Pepper giveaway makings06 5th Gen Camaro SS LS LT General Discussions 126 07-21-2009 10:32 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Camaro z28 concept design model has been found by yours truly, ponycrusher21!!! ponycrusher21 Camaro ZL1 Forum - ZL1 Specific Topics 30 06-17-2009 08:12 AM
Found Specs for 2LT Factory 19" Tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 0 04-05-2009 06:12 PM
Found this on COMP Cams 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 03-14-2009 01:53 AM
