Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Vendor and Seller review / feedback / experiences
Old 05-17-2010, 08:33 AM   #1
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Elite Oil Catch Can
I purchased an Elite Engineering oil catch can and I am very, very disappointed.
BTW, the price now is $175 though I was given $15 off. In any event it isn't worth the $160 in my opinion after the issues I've had.
The can came with 1 90 degree and 1 straight brass hose connectors, so I had to purchase another 90 degree brass connector. Elite's online install instructions for the 2010 Camaro oil catch can show 2 - 90 degree fittings. The paper instructions supplied with the kit are junk. I was only supplied enough 3/8" hose to make 1 connection, so had to purchase additional 3/8" hose. But the best poor quality problem is the large button head screw that holds the catch can mounting bracket to the round bar mount is either too big or the 2 small slotted holes in the bracket to mount the oil can are in the wrong place. The large button head screw ran into the oil catch can so the bracket to the oil catch can could not sit flush when the 2 small mounting screws are tightened. I had to grind the large button head screw face all the way around at an angle to finish the install. After this experience and the one I had with BBK I have to wonder if these vendors ever install their "products". Another over hyped, defect ridden product for the 5th gen Camaro.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 05-17-2010, 08:49 AM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
That sucks man, I was getting ready to order one myself. Guess i will hold off now and see what happens.
MODS:
Old 05-17-2010, 08:55 AM   #3
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Moved to the feedback forum.
Thanks for the write up.
Old 05-17-2010, 09:01 AM   #4
flht99b
flht99b's Avatar
Why move this post ??? Now very few will see it and may end up buying a defective oil catch from Elite Engineering. The BBK header thread was not moved to vendor/seller feedback/experience section. It was out there fro all to see in the bolt on section as should this thread be.
Ed M.
Old 05-17-2010, 09:03 AM   #5
GTAHVIT
Blessed
GTAHVIT's Avatar
We should have moved the BBK one also.
and I left a redirect for this thread.
so relax.
we have a feed back forum for this very reason. that way members don't have to dig for feedback it's all in one place.
Old 05-17-2010, 09:35 AM   #6
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
well i bought one and its one of the best made part's on my car, the bracket only fits one way , the two slotted hole's allow some clearance for the large bolt to fit, and the fuel hose is for the ls3 only you must buy more hose to fit the L99, no big deal, if you think all aftermarket parts should fit like it came from the factory your mistaken, usually you will have to make minor adjustments, the elite catch can is a universal part made for the corvette but modified for a camaro. i would contact elite about the problem before dragging there name through the the mud thats just wrong !
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
Old 05-17-2010, 09:46 AM   #7
flht99b
flht99b's Avatar
Mine is a LS3 so I didn't need long 3/8" hoses. Since I ordered this for an LS3 Elite should have included enough 3/8" hose AND the proper fittings ( 2 - 90 degree ). There was 1 piece of 3/8" hose that was about 2 inches longer than what I needed. Certainly not enough hose to make the 2nd connection. I know the bracket only goes 1 way, didn't matter as I bet the large button head screw they supplied is slightly different than the one they "prototyped" with. Without grinding the head of the bolt, the catch can wasn't going to seat in the machined relief for the bracket.
Sorry, MTI and CAI have done a far superior job engineering their products than Elite. I will be calling them today.
Ed M.
Old 05-17-2010, 10:11 AM   #8
adub4185
Drives: 2010 2SS RS, 2023 Camaro ZLE
Send a message via AIM to adub4185
Give them a call or send them an email. They are very responsive and will make it right. I helped design the mounting system and this is the first I have heard of any problems with it or the instructions. I do know that it should have included two 90 degree brass fittings and I am sorry to hear that they included the wrong one. I do know that they sell a lot of ones for the Corvette, which includes one 90 degree and one straight connection, so they may have just had a goof in shipping. Also, the amount of hose needed between the vette and camaro is different, so that might also have been caused by a packaging mix up.
As far as the button head screw and such, I havent heard any problems on this either. The one I have fits perfectly. I dont know what paper instructions were included, but the ones they have on their site are very thorough and are very easy to follow (I wrote them if you have any questions).
As I said before, If you have any questions let me know and I would highly suggest sending them an email. Steve and the guys will take care of you.
adub4185 is offline   Reply With Quote
Old 05-17-2010, 11:43 AM   #9
flht99b
flht99b's Avatar
Here is a picture of the bolt I had to customize in order to mount the oil catch can.
Ed M.
Old 05-17-2010, 12:05 PM   #10
adub4185
it might have been a mis-machined bracket then. The one I have is a tight fit, but it does all work. What I found is that you should install the bracket on the end of the shaft and then bolt the can to the bracket. The two machine screws will pull in the can and it will tighten down nicely.
Old 05-17-2010, 12:10 PM   #11
flht99b
flht99b's Avatar
"What I found is that you should install the bracket on the end of the shaft and then bolt the can to the bracket. The two machine screws will pull in the can and it will tighten down nicely. "
Exactly what I did, you can't install it any other way. When tightening the 2 small button head screws is when it was apparent the big button head screw was contacting the oil catch can housing long before the bracket was fully seated onto the oil catch can.
Ed M.
Old 05-17-2010, 01:41 PM   #12
adub4185
I would just contact them directly then if you arent happy and explain the issue. As I said before I haven't seen nor heard about the issue you are seeing.
Old 05-17-2010, 03:04 PM   #13
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
on a side note... RevXtreme has finally fixed all their bugs with their catchan. i finally got a revised bracket and a matching 90 degree fitting for the outlet. plus it is cheaper than the elite.
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 05-17-2010, 03:19 PM   #14
flht99b
flht99b's Avatar
Working via email with Elite all day. Sent them the picture I posted above and they said "something doesn't look right". They have said they will credit my CC $15.00 for my trouble and hardware I purchased. So, yes, EE is working to resolve this. I have to wonder how I had a problem when no one else seemed to. Maybe like the BBK fiasco, there has been an unintentional change in the production parts at EE that has gone unnoticed.
As a customer I really don't care, the point is I shouldn't have to go through this with 50% of the Camaro5 vendors I have dealt with. Everyone rushed a product to market as a new cash cow was born and as what has become BAU in the 21st century, quality is not job one. Customer care after the fact, though commendable, does not cure all.
Ed M.
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 05:15 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 11:35 AM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
