Old 05-17-2010, 11:47 AM   #1
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
AM lowering springs, normal of not?
hearing the rear? suspension(springs) whenever going over a bump. Is this normal, due to the drop in height(spacing)? Checked seating, bolts, etc..all is OK..using Eibachs, and did not trim the bumpstops..
Old 05-17-2010, 12:07 PM   #2
Droid6
Droid6's Avatar
Drives: 2010 Camaro LS
You'll probably get a better answer in the Suspension/Brakes/Chassis sub-forum.
Droid6 is offline   Reply With Quote
Old 05-17-2010, 01:30 PM   #3
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
There was a thread about the rear "clunk" when you put in lowering springs... was like the lowering springs were causing the strut bushing to deflect more causing the top of the strut to hit the body... or something like that... I have the clunk, although it's not as pronounced now... seem the worst when I "twist" the car... like turning up a steep driveway..
scrming is offline   Reply With Quote
Old 05-17-2010, 03:53 PM   #4
deljaso
deljaso's Avatar
Drives: 2010 1LT/RS
It's been happening on my car since I installed lowering springs -- only on the rear driver's side corner. It happens on little bumps, it almost sounds like a rattle.
I haven't gotten around to trying to find if the top of the strut mount is hitting the bottom of the trunk sheetmetal. It's kind of a pain when you have subwoofer and amp sitting right over that part of the trunk. I would hate to have to drop the strut again.
I can see nothing making contact when I check out the visible portions of the suspension back there.
deljaso is offline   Reply With Quote
Old 06-27-2011, 09:58 PM   #5
1meanss
1meanss's Avatar
Drives: 2010 Black Camaro SS/RS
Is there a fix for this?
1meanss is offline   Reply With Quote
Old 06-28-2011, 02:30 PM   #6
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Check out leonardo's thread in the suspension section. Eibachs may not be made right and are making noise/to short for the application and moving a bit. he chanched out to Hotchkiss and no problems.
VR Baron is offline   Reply With Quote
H&R Sport Lowering Springs IN STOCK NOW!! AJ@ECSMotorsports Suspension / Chassis / Brakes 25 10-13-2010 10:35 AM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 10:32 AM
Eibach Lowering Springs & Sway Bars @ Phastek Performance Jason@Phastek Suspension / Chassis / Brakes 0 01-29-2010 03:56 PM
