![]() Drives: 2011 2LT RS RJT Join Date: May 2010
Cruise Control issues?
Wooott! so we took delivery today of a 2LT non-rs Camaro, Manual, black. LOVING it!
but I noticed something... the Cruise Control doesn't appear to work! I've owned a bunch of GM vehciles, and so I'm pretty sure I have the process down. (turn it on, push down on the set button, go!) It is a manual, so is there something else that needs to be done? Since I haven't seen anyone else report this issue, I'm thinking its a procedural thing... but maybe not. |
![]() ![]() ![]() Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
Mine is an auto , but it should be the same. Activate it then hit + or - to set it. A little light comes on in the dash.
The Yellow Camaro Club
![]() http://www.camaro5.com/forums/group.php?groupid=128 Northern Massachusetts & Southern New Hampshire Camaro Club http://www.camaro5.com/forums/group.php?groupid=127 The mother of all supercharger questions thread ![]() http://www.camaro5.com/forums/showthread.php?t=77958 My 2010 Camaro Review ![]() http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442 2010 Transformer Edition Camaro L99 Auto ![]() ![]() ![]() |
yeah light goes on when you turn it on and changes colour when it is engaged..
if you put your foot on brake or clutch it deactivates |
Interesting. Light is white, but never changes color. I'm guessing it supposed to go green when activated? Pressing up or down on the thumb wheel does nothing.
knows 2 facts about ducks
I mean I could be wrong here, but I'm curious to know the answer none the less. I don't think you can have cruise control in a 6spd, I don't actually know. Can you?
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
to set/decel u roll the button down
to accel u roll button up |
#7 |
![]() Drives: 2SS RS Join Date: Mar 2010
Had the same issue.
I had the exact same issue with my car. Light on the dash was always white, cruise would not set. I took it to the dealer and they had it fixed within a few minutes. They said the clutch sensor was slightly out of adjustment, so the cruise control always thought the clutch was depressed (Hence, would not set). Since they adjusted the sensor it has worked perfect.
#8 |
![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
+1 with the clutch switch. The body control module always sees the clutch is pressed down with the switch out of adjustment. Also try pulling up on the pedal with the top of your foot while trying to set the cruise and see if it works. This would again confirm just an adjustment with the switch or pedal travel is needed.
#9 |
![]() Drives: 2010 Camaro LS Join Date: Mar 2010
If this helps, you need to be atleast going 30 mph
#10 |
![]() Drives: Black LT Camaro Join Date: May 2010
The light on the steering wheel for mine does not come on anymore when I click on it. Any idea on how to change this?
#11 |
its supposed to go green
and you can have cruise.. i have a manual with cruise.. and try the dealer like said above.. |
#12 |
There have been numerous issues of failed clock springs connectors in the steering column. This the connector that allows the wiring from the steering wheel buttons to turn with the wheel and remain in contact with the stationary wiring in the column.
#13 | |
#14 |
sweet, I pulled the clutch back and it came on. Non adjustment necessary.. I'm guessing its just tight from being new?
| GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 02:56 PM |
| How to set cruise control??? | TomServo | 5th Gen Camaro SS LS LT General Discussions | 2 | 06-10-2009 08:52 AM |
| Does the 1SS automatic come with cruise control? | Camaro2010ss | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 05-27-2009 11:08 AM |
| Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 06:29 PM |
| U.S. plans to require stability control on all new cars | KILLER74Z28 | General Automotive + Other Cars Discussion | 3 | 09-14-2006 07:08 AM |
