Old 05-20-2010, 01:10 PM   #1
ron8879
ron8879's Avatar
Drives: 2018 Camaro RS
Question springs springs springs
alright, so I think im going to bite at buying some drop springs for hotrod.....heres the thing I'm looking for about a 1.2-1.4 drop, with leveling the back of the car (since the back sits up so high), I dont want to cut the bumpstops, dont want to bottom out the back (the dreaded clunk), and I got about 300 bucks to do it with since I still will have to get an alignment...i've got one or two in mind but I'm looking for feedback from members to see what the suggestions are...
btw...swaybars will be done later (fallish Im planning)
Fifty years from now, when you're looking back at your life, don't you want to be able to say you had the guts to get in the car?" :
HOTROD2010 VR RPO 14568...flowmaster exhaust, color matched antenna and drip rails, barton shifter, 4 pack gauges, leather armrest, color matched spoiler, and emblem delete, 20x9 chrome wheels
HOTROD2018...RS camaro LT1 Npp Exhaust, SS front brakes package and cooling packaage, black bowties, more updates to come!
ron8879 is offline   Reply With Quote
Old 05-20-2010, 03:55 PM   #2
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Use the search function
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 05-20-2010, 04:44 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
The 1.2 - 1.4 is going to limit you. A majority are 1" drops.
I think at the moment you'll have to choose either Pfadt or H&R. Both roughly $300 but Pfadt recommends cutting the bump stops and I've heard H&R are on the rougher riding end of the group.
Oh....almost forgot about DSE which I believe is a 1.4-1.5 but that will be out for you because they only sell them with their sway bars and you're looking at around $900 for that.
BMR might have a 1.4" eventually but last I heard they are still in development of them. They might be an option if you wait.
I went Hotchkis for the reasons as you're wanting except that I am good with the 1" drop. I got mine for $290 shipped and $80 alignment.
Build Journal
Old 05-20-2010, 06:54 PM   #4
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I put in the Pfadt drop spring (I also put in their sway bars and end links). The drop with Pfadt is about 1.25".
I got my Pfadt suspension through IPS Motorsports. IPS Brandon is a member of these forums and he got me a great price. Send him a PM for a quote.
Old 05-21-2010, 09:59 AM   #5
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Why do you not want to cut the bump stops? There is ABSOLUTELY NO issues with trimming the bump stops , whether we install a Pfadt Eibach H&R spring we always trim the bump stops, this is proper procedure for any lowering spring in my opinion.
Aside from that point if you are looking 1.2- 1.4 " drop the Pfadt springs are perfect for you, they also can be purchase with in your budget through me Just message me.
These will not clunk, or bottom out under normal driving conditions, obviously if you hit a space crater of a pothole, it may in fact bottom out.
Regards
IPS Brandon is offline   Reply With Quote
Old 05-21-2010, 11:50 AM   #6
killinemsoftly
killinemsoftly's Avatar
Drives: Summit White L99 2SS Forgiato 22"
I have H&R's and rides great and no cutting of bumpstops is recommended
White 2SS H&R Springs, Blacked out emblems and lights , black roof, Forgiato Martellato Custom Painted 22's
killinemsoftly is offline   Reply With Quote
Old 05-21-2010, 11:25 PM   #7
ron8879
ron8879's Avatar
killinemsoftly.....any problem with bottoming out?
ips brandon...other than installing a spoiler cutting/drilling is not something I want to do with my car...I also dont feel the bumpstop will hold up as well with having its structual intergrity messed with...but I may give you a shout for sure when im ready to buy
caverman....im intersted in Hotchkis but they show them for the SS..Im 90% sure they would fit, but would I get more than a 1 inch drop since my car sits higher than the SS from the factory? Also, did u have to cut the bumpstops?
thanks everyone for taking the time to respond and if anyone has more imput i absolutely welcome it.
Old 05-22-2010, 12:28 AM   #8
killinemsoftly
no bottoming!
Old 05-22-2010, 12:37 AM   #9
deljaso
deljaso's Avatar
Drives: 2010 1LT/RS
Have you seen the bumpstop on the struts? It's a circular rubber/foam piece on there. It looks like it's disposable, really. Structural integrity couldn't be compromised, when you cut it you're just taking it down from 2 inches high to 1 inch high.
I can't imagine a set of them being more than $10 to replace.
deljaso is offline   Reply With Quote
Old 05-22-2010, 03:34 PM   #10
Darth_Emma
Darth_Emma's Avatar
Let me just add... drop springs and sway bars = do eeeeeeeet! Your brakes will thank you on the twisties!
Old 05-23-2010, 12:28 PM   #11
ron8879
ron8879's Avatar
so heres a question...if the springs say you will get a 1" drop on a ss will you get more drop on a 6 since the car sits higher from the factory?
Old 05-24-2010, 11:00 PM   #12
ron8879
ron8879's Avatar
bump
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 11:32 AM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
