Old 05-21-2010, 05:19 PM   #1
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
Taking off the front bumper
Has anyone done this by themselves with or without ground effects. Was it as easy as I saw in the AAC video. I personally have the ground effects on and was wondering if you have to do anything different when taking out the screws. I'm taking it off to go and get it repainted and wanted to do the labor part my self because the dealer was going to charge me like $69/hour for 3.5 hours to take it off themselves. I would rather take it off. I need to know how anyway if i'm ever going to replace my headlights.
Chad's ZL1 is offline   Reply With Quote
Old 05-21-2010, 05:30 PM   #2
unrestrictedmotorsports
unrestrictedmotorsports's Avatar
Drives: 2011 Comp 6 Turbo
Its easy to take off the front fascia
Take out the fender liners on both sides. There are four 10MM bolts that need to be removed on both sides. Also you need to detach the wiring harness that is connected on the passenger side that is connected to the black bumper support. There are also a hex screw that holds the front bumper close to the fender right in front of the side markers. There are (2) 10mm bolts up top in the engine bay that need to be done and also the plastic tabs that need to be removed too. Then there are (2) 10mm bolts on the bottom side that are screwed into the frame. Thats it. I think once you get into starting it you will see how easy it is.
If you take your time it should not take you longer than 1 hour for the whole bumper since it is your first time. I am able to get the bumper off with 30min after taking off several fascia already.
unrestrictedmotorsports is offline   Reply With Quote
Old 05-21-2010, 05:42 PM   #3
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
What he says is true
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 05-21-2010, 08:06 PM   #4
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
cool thanks.
Old 05-21-2010, 08:51 PM   #5
Captain McFunk
Break Necks, Cash Checks
Captain McFunk's Avatar
Drives: 2010 black Camaro 2SS/RS
I took off the bumper yesterday without taking out the liners (only the 3 screws on the front on each side) by myself. It took about 30 minutes to get the bumper off by myself. It's not hard at all.
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
Captain McFunk is offline   Reply With Quote
Old 05-21-2010, 11:30 PM   #6
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
AAC has a video removing the front from my daughter's Synergy.
Shuffler is offline   Reply With Quote
Old 05-21-2010, 11:39 PM   #7
darknite30
2010 Camaro SS/RS - Black
darknite30's Avatar
Drives: 2010 Camaro SS/RS - Black
link?
darknite30 is offline   Reply With Quote
Old 05-21-2010, 11:51 PM   #8
CaliEMT
Decepticons. . . MOBILIZE
CaliEMT's Avatar
Drives: 2010 2SS/RS Black
LOL!
They SAYYY its easy. Well it is, but you have to remove your front Ground Effect Chin to take off the spoiler or else it Will not come off.
Trust me.
CaliEMT is offline   Reply With Quote
Old 05-21-2010, 11:53 PM   #9
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
30 minutes tops, by yourself
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 05-22-2010, 01:12 AM   #10
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
So I have to take off the front ground effects completely? it's just held on underneath by tabs or bolts right. Not sure why I would have to take off the ground effects. I thought that the bolts that you need to take out from underneath went through the ground effects.
Old 05-22-2010, 01:17 AM   #11
CaliEMT
CaliEMT's Avatar
Well thats what I meant. There are Two or four (hmmm I think two) that Screw the ground effect chin onto the Chassis I beleive. Feel the tip of the Chin and run your fingers back you should Find them.
Old 05-22-2010, 01:19 AM   #12
Shuffler
God Bless Dawson
Shuffler's Avatar
Originally Posted by darknite30 View Post
link?
Old 05-22-2010, 09:13 PM   #13
Great video but I only see one problem with it. There is a10mm bolt that it attached behind each side marker that has to be removed since it is connected to the fender and also there is another T20 from the front bumper to the fender that is attached vertically. Maybe the V6's are different but i dont think they are.
Has anyone else see that too?
Old 05-22-2010, 09:59 PM   #14
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
I wouln't see why the V6 is any diffrent than the V8 when it comes to the bumper.
Dreading Holes In My Front Bumper Hosed 5th Gen Camaro SS LS LT General Discussions 29 05-15-2010 06:41 PM
99 Firebird Formula to T/A front bumper swap hollywoodGU 4th Generation Camaros 5 05-12-2010 02:57 PM
China Bumblebee front bumper? LF-SS Cosmetics and Lighting Modification Discussions 11 08-06-2009 08:56 AM
Can we get a front plate holder that bends with the bumper? edog Cosmetics and Lighting Modification Discussions 45 02-25-2009 12:36 PM
