Old 05-22-2010, 02:39 PM   #1
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
DIY Brake Calipers Rotors and Line Removal
Hi everyone tore down my brakes today for paint and upgrades!!!
Tools Needed!
Impact Gun or 1/2 in breaker bar
7/8's or 22mm socket
18mm socket
10mm socket
30 star bit
13mm line wrench
18mm wrench
11mm wrench
Pilers
Hammer
Small Drift Punch
1/2 in and 3/8 in rachets
Lowrider Jack my Camaro is lowered almost 2in
4 2 ton jackstands
Step One: Jack up car and support with jack stands
Step Two: Take off wheels
Step Three: Remove brake lines 11mm wrench on cailper and 10mm on the hold down 13mm line wrench where it connects to the hardline also need the pilers to remove retaining clip that holds the rubber line in place for the hard line
Step Four: Remove cailper pins small drift punch and a hammer do wonders then pull out gently on the pins with pilers holding brake pads
Step Five: Remove brake pads pull or push out pads should move easily!!!
Step Six: Remove 18mm bolts that hold Caliper and remove Cailper the 18mm bolts were tight might need a breaker bar or impact gun I had to use an 18mm wrench on the rear bottom bolt because my coilovers resivors were in the way
Step Seven: Remove star screw from rotor and pull off rotor 30 star bit turns out easy
Step Eight: Repete three more times!!!!!!!!!
Takes about 1/2 hour to hour plus I was doing the DIY pics!!!
Few weeks and I will do a reassemble with new parts!!
Gotthat02fire is offline   Reply With Quote
Old 05-22-2010, 02:44 PM   #2
Gotthat02fire
PICS!!!!!!!
Old 05-22-2010, 02:48 PM   #3
Gotthat02fire
More Pics!!!!
Old 05-22-2010, 03:02 PM   #4
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
What is the picture showing the drum brakes.? Is that the emergency brake? Why is it only on one side? Just curious. i will be changing out my calipers tomorrow for my new powdercoated calipers.
Fishdadddy is offline   Reply With Quote
Old 05-22-2010, 03:08 PM   #5
Gotthat02fire
It is in the rear only it is for your e-brake! It is both rears I only showed one side being ripped down!
Old 05-22-2010, 03:17 PM   #6
Fishdadddy
Fishdadddy's Avatar
So I won't have to mess with the E brake to just change calipers I guess?
Old 05-22-2010, 03:30 PM   #7
Gotthat02fire
You won't even have to touch th e-brake!!!! Not even if you where changing your rotors!!!
Old 05-22-2010, 04:32 PM   #8
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
If I just want to paint my calipers, how much of your DIY instructions do I need to do? How long will my car be out of commission (i.e. paint drying, etc.). Mine's a daily driver, but if the downtime is just for a weekend, I can do that, I think.. Thankx, Lori
CaniacFan is offline   Reply With Quote
Old 05-22-2010, 04:40 PM   #9
Fishdadddy
Fishdadddy's Avatar
Cool! Thanks Bro
Old 05-22-2010, 08:22 PM   #10
Gotthat02fire
If your painting them with a bush they can remain on the Camaro if your haveing them painted or powder coated to matched your Camaros color than you just need step one to six!!!!!!
Here is a link to paint that is brushed on!!!!!
http://www.tirerack.com/brakes/acces...tail.jsp?ID=41
Others on the forum have used with great results!!!
Old 05-24-2010, 11:44 AM   #11
Gotthat02fire
Updated with more info in the write up this is my first DIY so if something isn't right or you need more info don't heistate to ask!!!!!
Old 05-24-2010, 05:26 PM   #12
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
Thanks, Great write up and pics! Im taking my calipers off in a week or 2 to send them off for powder coating, when the hoses are disconnected, how do you stop the fluid leakage?
Cheers
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 05-25-2010, 10:15 AM   #13
Fishdadddy
Fishdadddy's Avatar
Cheers
That's a good question. I just replaced my calipers this weekend with new Powdercoated calipers. I did a core exchange deal with Mike The Powdercoater. So I had the new ones and the old were still on the car. After swapping thenout I send him back the old calipers.
Not sure how you would plug the lines for any length of time, to be able send the calipers out and wait for them to come back.
ANYBODY ELSE KNOW?
Old 05-25-2010, 11:53 AM   #14
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
I know that text in CAPS mean you are shouting.
What does text in bold lettering mean?
tradosaurus is offline   Reply With Quote
Racing Brake 2 pc Rotors Installed mtcwby Suspension / Brakes / Chassis 36 11-13-2010 06:07 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
Need Stopping Power? Baer 15" Six Piston Brake Upgrade now available! Kris@BMCPerformance Suspension / Chassis / Brakes 11 12-10-2009 07:50 PM
Baer 15" 6 Piston Extreme Plus Brake Upgrade for 2010 Camaro Available Now! Kris@BMCPerformance Suspension / Chassis / Brakes 6 11-04-2009 10:17 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 02:44 PM
