Old 05-23-2010, 08:28 PM   #1
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
Pfadt subframe mounts
I was speaking with the owner of pfadt this weeken at brainerd raceway in mn about the solid subframe mounts, anyone have these and what do you think of them.
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 05-23-2010, 09:15 PM   #2
jrpxxii
jrpxxii's Avatar
I have them in my car and also the diff bushings along with every other suspension component so I can say that wheel hop is gone and there is no movement in my rear end...(no pun intended LOL) but I think I finally have my car setup to hookup at the track. You can trust anything Aaron tells you as he is very honest and will give a honest opinion and Pfadt products are top notch. I also have Spohn, BMR and Pedders suspension equipment so I can share the love. Be aware though, the installation is not for the faint of heart but a little sweat and patience it went fairly smooth.
Old 05-23-2010, 09:15 PM   #3
Petersimov
Drives: 2ss
got them love them all that needs to be said
Petersimov is offline   Reply With Quote
Old 05-24-2010, 01:08 PM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey stealth! Glad to see you came out to the track. You watch the races at all? The Camaro was on-point!
Old 05-24-2010, 02:48 PM   #5
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
I finally got around to doing my first installation on a set (aside from watching a few or our technicians) and overall it was not to bad at all (on a lift that is).
The subframe comes out in minutes, I think 25 minutes and I had it out...Cutting the bushings with a nice long sawzall made life easy and then reinstall was just as simple. How ever on jack stands this could be a little more of a job.
Taking the car for a drive after words, WHAT A DIFFERENCE.
Regards
IPS Brandon is offline   Reply With Quote
Old 05-24-2010, 03:53 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Interesting...
Old 05-24-2010, 07:32 PM   #7
Stealth 2010 2SS/RS
yes, the camaro that was racing won its class, would you recommend doing the rear diff bushings at the same time as the rear sub frame mounts. cant thank the owner enough for spending the time to talk with us and watch the race with us.
Old 05-24-2010, 09:38 PM   #8
Petersimov
Drives: 2ss
stealth are u the same stealth form the cts-v forum
Old 05-24-2010, 09:59 PM   #9
Stealth 2010 2SS/RS
No, I wish I had a cts-v also
Old 05-24-2010, 10:34 PM   #10
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
How much would install usually run w/ these?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 05-25-2010, 02:40 AM   #11
Luvpilot
Luvpilot's Avatar
Drives: GM
This!
Luvpilot is offline   Reply With Quote
Old 05-28-2010, 09:47 AM   #12
IPS Brandon
We charge 3.5 hours to install the sub frame bushings. I believe 4-5 hours is what is recommend. In terms of dollars, rates vary wildly for many shops so I can not comment there, but this should minimally give you a time budget.
I would also add if you are planning on doing diff bushings it is much easier to do so while the rear subframe is out of the car, they are a very nice upgrade.
-Regards
Old 05-28-2010, 09:50 AM   #13
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
The Pfadt solid subframe bushings are worth every penny. They eliminate any subframe deflection. Nice for transmitting the engine energy (horsepower) to the ground. If you order these you may want to get the motor mounts too... As the engine builder said "Without those, the engine moved like a Rock Band" (True story...)
Old 05-30-2010, 02:41 PM   #14
SSMagna
FAST1
SSMagna's Avatar
Drives: ADM LSX 427 Twin Turbo #1
ADM just changed mine out with the dif bushings also and it still walks side to side a little in 3rd gear. I have had it aligned twice it still does it. 130 mph rear end "step outs" are not fun. The tires are not breaking loose it just won't stay straight.
SSMagna is offline   Reply With Quote
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 01:09 PM
Subframe Bush Upgrades. From Simple DIYer to Full Race Capable Info@PeddersUSA.com Suspension / Brakes / Chassis 16 05-03-2010 10:29 PM
VIDEO of Pfadt testing their NEW rear subframe mounts! PfadtRacing Camaro Photos | Spyshots | Video | Media Gallery 25 03-22-2010 05:11 PM
Pfadt Engine Mounts installed, first and second impressions... robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-03-2010 10:35 AM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
