05-26-2010, 12:02 AM | #1 |
Delete this account
Drives: Delete this account Join Date: Mar 2010
Delete
Delete
05-26-2010, 01:06 AM | #2 |
Spartan Performance
Drives: it like I stole it Join Date: Jan 2010
Not one. Personally, I wouldn't do it. I've never disconnected the battery for the MULTIPLE installs I have done. Don't see any reason to start now.
05-26-2010, 01:21 AM | #3 | |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Of course, leaving it connected you'll see those same changes, but it will take anywhere from 150-500 miles. It won't hurt to do it and, hey, at least Onstar won't know where you are for a few minutes...lol.. -Ivan |
05-26-2010, 02:04 AM | #4 |
Drives: 2010 Camaro Black 2SS Join Date: May 2010
it only takes a minute or two to disco the battery, so ill do it because it says too.
05-26-2010, 06:10 AM | #5 |
Well the problem is the computer system has a battery backup in it. So pulling the battery is not resetting anything but window indexing unless left disconnected for days.
To reset the ECM just pull fuse 5 and 20 in the engine fuse box for 1 hour at least. This will get the computer to reset to default and relearn everything when you fire up the car. I recommend letting the car idle for 10 minutes after doing this to let the computer learn. The drive easy for the first 10-20 miles before doing a WOT for the computer to learn faster. |
05-26-2010, 06:42 AM | #6 |
Drives: '10 Camaro 2SS/RS Black Join Date: Jul 2009
Well, if something happens and you didn't disconnect the battery like the manu. says, they will tell you they can't help you. Food for thought, it only takes five mins to disco and connect again.
2SS/RS A6 L99 - Black w/White Stripes
K&N Air Intake System Muffler Delete |
05-26-2010, 10:41 AM | #7 | |
Drives: abm2ssrs Join Date: Apr 2009
[SIGPIC]
05-26-2010, 11:02 AM | #8 |
Drives: '10 SS CGM #75,288, '14 Stingray Join Date: Aug 2009
So, for those who have installed CAI's - just follow the instructions and I'll be good?
05-26-2010, 11:08 AM | #9 |
Drives: 2005 GTO, 1973 Camaro Join Date: Aug 2009
I've always disconnected the battery for 10 mins so the computer can reset itself. Like everyone else said, its not mandatory but recommended so the computer resets and learns the new modifications.
That is why sometimes a CEL comes on and then turns off after 50 miles or so. The computer is trying to learn the new mods. By reseting the battery you are starting off fresh again. |
05-26-2010, 12:18 PM | #10 |
id usually only disconnect the battery for safety issues on any of my other vehicles. these new cars and there computers, id probly do it because im not sure what it will do with the computer.
brian
2010 camaro SS. LS3/6SPD (sold) 2003 Jeep Wrangler/Rubicon/NV3550 1989 F-150 4x4/300 I6/M5ODR2 1982 mustang. 351W/414stroker C4 9" rear. bracket racer 1977 F-100 5.9L 12V Cummins conversion/NV5600 |
05-26-2010, 12:57 PM | #11 |
05-26-2010, 02:17 PM | #12 | |
Catch me if you can
Yep, you won't have any problems with that. Your car will relearn the Air to fuel ratio just fine with normal driving.
05-26-2010, 02:21 PM | #13 |
Drives: 2013 Camaro ZL1 Manual Join Date: Mar 2010
I didnt see anything in cold air inductions instructions about disconnecting the battery??? Car seems to run great though...
Similar Threads | ||||
Battery Questions | UA488Fitter | 5th Gen Camaro SS LS LT General Discussions | 31 | 02-26-2012 09:26 PM |
Trunk mounted battery replacement | sting808 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 0 | 01-11-2010 05:42 AM |
GM To Build Battery Plant | Mr. Wyndham | General Automotive + Other Cars Discussion | 5 | 01-13-2009 01:03 PM |
changing a battery in the wintertime is FUN | Dave McFly | General Automotive + Other Cars Discussion | 10 | 11-20-2008 05:37 PM |
Chevrolet Volt | Urthman | General Automotive + Other Cars Discussion | 160 | 09-29-2008 08:17 PM |
