Old 05-26-2010, 04:44 AM   #1
Cabrera
Freightrain Coming Ur Way
Cabrera's Avatar
Drives: V8-1968 & V6-2000 & V6 2010 Camaros
V8 / V6 exhaust
I have been thinking for 2 days where to post this... on the V8 section, on the general discussions or here on V6...... so here it is.....
After much search, reading and debate on numerous exhaust systems, from cat back to axel back, to straight pipes and so on....adding horse power and what not... bottom line is the V8 and V6 and very much alike symetrically and V8 bolts on directly to the V6 no matter if it's stock, or after market.
Why couldn't we.... or what would be the problem on any aftermarket V8 exhaust and installing it on a V6?
Other question is any problem with just cutting off the muffler and going a straight pipe? how would any after market exhaust enhance it otherwise?
Do you serve a purpose, or purposely serve?
Cabrera is offline   Reply With Quote
Old 05-26-2010, 05:35 AM   #2
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
straight pipes sound like ass on the v6 trust me i did it and as far as i know you can put a v8 kit on the v6 or atleast the cherry bomb kit
rhd is offline   Reply With Quote
Old 05-26-2010, 06:59 AM   #3
Cro
Cro's Avatar
Drives: Raincheck on that one
http://www.camaro5.com/forums/showthread.php?t=81962
The V8 exhaust will fit on a V6, this guy did it with the Cherry Bomb exhaust. It ups the size of the pipes from 2 1/4" to 2 1/2" and has an x pipe, which SHOULD mean all V8s will work
Cro is offline   Reply With Quote
Old 05-26-2010, 12:18 PM   #4
John VS
John VS's Avatar
Drives: 2010 Camaro 2LT CGM, IOM Int.
Yes, they are interchangeable. I have the Doug Thorley catback which is identical between the V6 and V8.
John VS is offline   Reply With Quote
Old 05-26-2010, 01:21 PM   #5
LASNOW
LA Snow
LASNOW's Avatar
Drives: 2010 Camaro 2LT RS
need help want to put axel back exhaust on 2lt not sure what brand. worried about dron can anyone help thanks
LASNOW is offline   Reply With Quote
Old 05-26-2010, 05:04 PM   #6
fixxer56
Thin Blue Line
fixxer56's Avatar
Drives: ABM 2LT/RS #10094
Send a message via AIM to fixxer56
I just switched my Axel back Magnaflow Supper 44's to Dynomax Vt's...Mucho Drone with the Magnaflows, none at all with the Dynomax. Hopefully will get a clip of them soon to post.
One of the "Few Blue"
Old 05-26-2010, 08:16 PM   #7
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
You still will have the ugly ass "gas tank" mufflers showing at the rear with the V8 swap...
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 05-27-2010, 12:06 AM   #8
KMPrenger
KMPrenger's Avatar
Hrmm...I'm guessing you meant Flowmaster Super 44s??
Don't think Magnaflow makes Super 44s....but if I'm wrong Im wrong.
Old 05-27-2010, 12:10 AM   #9
camaro guy
camaro guy's Avatar
SLP Loudmouth II. my vid. little drone.
camaro guy is offline   Reply With Quote
Old 05-28-2010, 06:28 AM   #10
Cabrera
Cabrera's Avatar
so far..... not a good idea to just remove the mufflers and put in straight pipes and exhausts swap, whether stock or aftermarket........debate aside from performace..... seems to be raspiness sound or too much drone depending on the brand
Old 05-28-2010, 09:08 AM   #11
D Vegas
D Vegas's Avatar
Drives: 2010 1LT/RS VR,1978 VW BUG CV
I put the Pypes V8 Kit on mine, its 2.5in mandrel bent stainless with pypes M80 mufflers and x pipe.
D Vegas is offline   Reply With Quote
Old 06-21-2010, 07:48 PM   #12
lgndlt5
lgndlt5's Avatar
Drives: 2010 1lt
Does the SS exhaust (it has 2-1/2" od pipes bolt to the V6 cats?
The V8 exhaust will fit on a V6, ...... which SHOULD mean all V8s will work
Screaming or ? Does anyone know if the outlet pipe on the V6 LLT cats is compatible with the 2-1/2" OD SS pipes (on the full OEM SS cat back system), where they meet the cats? I would like to know if the SS exhaust TRULY will fit the V6 at the back of the cats? Do the factory SS 2-1/2" OD pipes fit nicely over or inside the V6 (2-1/4"??) cats or just exactly how does that work? Thanks in advance any one who contributes but especially those who actually are sure about the answer. I want to do this at home if possible. Thanks!!! John
lgndlt5 is offline   Reply With Quote
Old 06-21-2010, 08:02 PM   #13
mrray13
Drives: 2010 1LT RS Rally Yellow
The v6 is 2.5" exhaust until the factory resonators, at which point it drops to 2.25", IIRC. That's why v8 cat backs fit.
mrray13 is offline   Reply With Quote
Old 06-21-2010, 09:34 PM   #14
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
It will fit just fine, but you won't like the sound of it. Trust me I know this.
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 09:38 AM
GROUP BUY- Mach XL V6 (Manual) and Mach XLT V6 (Automatic)- Ends 11/30/09 GOINGSOLO2 V6 Bolt-Ons & Tunes 252 10-20-2011 09:33 PM
Jay leno hints to the z28 in video!!! tru imperial blu Camaro ZL1 Forum - ZL1 Specific Topics 103 11-27-2009 10:56 AM
V8 Corsa Exhaust in stock and available GmPartsDirect.com V8 Bolt-Ons & Tunes 3 10-29-2009 09:28 AM
V8 appearance vs. V6 Discussion! jpsuperman81 5th Gen Camaro SS LS LT General Discussions 19 08-08-2009 10:01 AM
