Old 05-26-2010, 05:43 PM   #1
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
bug and tar remover bad for paint
Sorry if this has been asked already, did a search and not finding a clear answer. Got some nasty bug guts on the front of my car that dont come off with normal good hand washing. Are the Bug and Tar removers bad for your finish? Anything else work better
cybercoaster is offline   Reply With Quote
Old 05-26-2010, 09:04 PM   #2
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
They are safe for paint. I think they are basically just Kerosene.
I've also used goof off safely on paint. Not so much on touch up paint though. It will remove touchup paint.
I suspect the tar and bug remover is not safe on touch up paint.
skuttduck is offline   Reply With Quote
Old 05-26-2010, 10:13 PM   #3
cybercoaster
Originally Posted by Chief Blackhawk View Post
Dude take a fabric softener sheet keep it nice and wet and the bugs come right off without scratching the paint.
Great tip, I will give that a try. Thanks!
Old 05-26-2010, 10:59 PM   #4
PHEOX
Drives: '06 Jeep Wrangler
If that doesn't work, get some clay bar, and I promise with some work that will take it right out and make your paint nice and glassy all at the same time. And, I keep wondering why bugs are so stupid as to not fly above the large moving objects that look threatening, like a 2010 Camaro. I personally wouldn't want to get hit by a 3800 lbs beast!
PHEOX is offline   Reply With Quote
Old 05-26-2010, 11:08 PM   #5
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
It's safe. But you have to use it on a cool surface and make sure you rinse it off good.
If you're that worried Rain-X makes a bug and tar spray, it's like a gel that you spray the bug down with first, then you wash your car. Works great.
Old 05-27-2010, 06:55 AM   #6
Pumpkin1LT
Drives: 2010 Camaro 2SS
Maguiers Quick detailing works GREAT on bugs and other road FOD...
Pumpkin1LT is offline   Reply With Quote
